Help: My car will not accept any fuel!!!!
I cannot figure it out
I am totally out of fuel (still drives) 0 miles to emtpy on the computer.
When I try to put fuel in, it just spits back at me????
Will not accept fuel
Is there any way to manually release vapors or vent the fuel filler neck?
please advise.
Marty Kaye
please advise.
Marty Kaye
I found this old thread on the same topic at Renntech. Hope it helps.
http://www.renntech.org/forums/index...c=6615&hl=fuel
Dock,
it must be some internal flapper (in the neck) because I cant even put in more than
a half a cup before it spits up. Can I poke something down there or is it a shop
repair (when he puts in my new rear (H&R) sway bar?).
thanks guys if you have any home remedies that do not involve a roto rooter cable...
MK
MK
does the fuse have power? if it has power youg gonna need to check the system
if you open the door in the fuel neck can you hear it click ? can you hear the lower valve click
Professor of Pending Projects
Originally Posted by Woodster
E6 fuse is fine ?????
what to try next?
MK
what to try next?
MK
Okay, picked up the car this evening.
They found a bad valve in the fuel tank and replaced the hoses too.
It took them 8 hrs. to perform.
Its the solenoid valve that operates the mandatory flap on filler neck (hydrocarbon release to atmosfere). I was told that in SOS you can fill VERY VERY VERY slowly (30minutes for a 1/2 tank) but I'd suggest to use a hose to push the flap open and then syphon the fuel in.
Electrical solenoid in gas tank opening.
Had this problem after some rats ate through some wiring (LONG story ...). There is a solenoid that controls the opening of the gas tank. The solenoid is either broken or you have some electrical issues. You'll need to get the thing to the repair shop, but this it is quick to fix.
