996 Turbo Forum 1999-2005
Help with Alarm please?
Old 08-20-2006 | 02:39 PM
Michael Ontic's Avatar
Michael Ontic
Default Help with Alarm please?
The problem: When I leave the car for 4 or 5 days with the alarm set.....then when I try to open it the key button won't unlock the car / dis-arm the alarm. I can then open it manually, setting the alarm off....until I turn the ignition on. At that point all returns to normal.....the key controls/alarm then work fine. You might think it's the key battery, but that is fairly new, and the red LED on the key flashes hot/fast with the key alarm button pussed indicating its transmitting.
Any suggestions please ?? Thanks in advance for your help. Mike
Old 08-20-2006 | 02:47 PM
Woodster's Avatar
Woodster
the key automatically deactivates the remote portion after 7 days (I believe it is seven).
this requires manually putting key into door slot to open.
MK
please join rennlist.
Old 08-21-2006 | 01:55 PM
wross996tt's Avatar
wross996tt
I think the alarm system deactivates the Key FOB after 5 days of no use. To reset the remote, unlock the door manually then hit the remote button and voila you are back to normal.
Old 08-21-2006 | 02:08 PM
99firehawk's Avatar
99firehawk
normal operation the vehcile goes into sleep mode and requires the key put into the door to wake it up
