camber settings
camber settings
Norm Goldrich said he has 1.2 degrees negative front and 1.3 degrees negative rear with Kumhos on his car.
How did you get 1.2 on the front? The best I could do was about 0.9. Stock ride height. No I have not gone to GT3 control arms or filed the slots yet.
Also what size Kumhos?
Michael Wilson
Michael Wilson
I do have H&R lowering springs otherwise everything else is stock.
I dont know if the shop notched the holes or not, but I dont believe they did...
Norm
2001 996 TT
Norm
2001 996 TT
The Kuhmos are :
225 40 18 front
285 30 18 rear
If my memory is correct.
Unfortunately that is the widest rear Kuhmo makes in 18. My stock rears were 295...
Norm
225 40 18 front
285 30 18 rear
Norm
Mike: As Norm pointed out, you will have to lower your car to get more than 1 degree negative in the front. I believe ROW ride height will allow you to attain your goal.
