996 Turbo Forum 1999-2005
996tt brake upgrade ideas?
Old 04-25-2003, 06:49 PM
JohnM
JohnM's Avatar
Post
soon2be: some race applications use brake fluid recirculation systems to help keep the fluid temperatures down. You can find some info on that and (race) braking systems in general here: <a href="http://www.prosystembrakes.com/technical_info.htm" target="_blank">Pro system brakes technical info</a>
Old 04-25-2003, 08:48 PM
cobra06
cobra06's Avatar
Post
This unit attach's to the master cylinder.
(Sierra Racing)
<img src="http://www.aarrf.com/amigos/images/surestop_Q.jpg" alt=" - " />
Some events have restrictions on rotor size, caliper specs. So they turn to these for extra cooling. While certain other events have restrictions on recirculators use. Mostly circle track stuff from what I remember. They cost about $150.00 and from what I understand work very well, certainly less then a set of giant Brembo's.
Old 04-25-2003, 09:31 PM
cobra06
cobra06's Avatar
Post
<a href="http://www.aarrf.com/amigos/DPI.html" target="_blank">DPI Sierra products</a>
Outlaw makes one, that is self-bleeding.
<img src="http://members.aol.com/xjguy/auto6/recirculator.JPG" alt=" - " />
<a href="http://members.aol.com/xjguy/auto6/" target="_blank">Outlaw</a>
Pitstop sells both.
<a href="http://www.pitstopusa.com/BRAKES.htm" target="_blank">Pitstop racing</a>
Old 04-26-2003, 10:49 AM
rmrmd1956
rmrmd1956's Avatar
Post
When I did my only track day, my brakes boiled and failed from overheating. It spoiled my fun as the car performed well in every other way. If I put a gt2 front on, will I improve braking? Will the aerodynamics be screwed up if I leave the 'regular' tail. I don't want to change pads to go racing and I can't stand 1 millisecond of squelling. What pads should I use and how can they prevent my brakes from boiling w/o different fluid? What fluid do I run that I don't have to keep changing?
Old 04-26-2003, 01:22 PM
cobra06
cobra06's Avatar
Post
CJV. I'll check on it.
Dan Press, is supposedly the most knowledgeable on this subject. They have a nice looking unit that is supposed to work on all calipers. I've got an email in to him.
They have a diagram of the system there as well, under brake recirculators.
<a href="http://dpiracingproducts.com/products.php" target="_blank">DPI industries</a>
Old 04-26-2003, 04:28 PM
cobra06
cobra06's Avatar
Post
Pitstop
Customer Service
<a href="http://www.pitstopusa.com" target="_blank">www.pitstopusa.com</a>
707-207-0193
Business Hours:
Monday thru Friday
8:00 AM to 6:00 PM
Pacific Time
When I hear back from DPI, I'll let ya know
Old 04-27-2003, 01:41 AM
DV 993tt
DV 993tt's Avatar
Post
Someone should make a kit utilizing Cayenne calipers. They are huge! Bigger than anything I have ever seen.
Quick Reply: 996tt brake upgrade ideas?
