Tuning 996 TT
Tuning 996 TT
I would like to tune my 996 turbo some more as I already have a Europipe stage 2 loud and a 1.0 bar program.
I do not want to rebuild the engine for more power, I would like to just use bolt on parts so what do you guys recommend would be a safe and effective modification for the car?
Also what would you guys say is the most power I can get without doing anything internal?
Thanx in advance,
Nick.
Thanx in advance,
Nick.
Turbo's ,some headwork and camshafts with the appropiate code will get you a reliable ~600 hp and can be counted on for sustained loads. At ~ 650 hp the rods should be upgraded.
since the question was how to get the most power without internal mods, changing the turbos from K16 to K24 or something fancier like a modded hybrid Kevin type, add changing the plenum, and larger intercoolers with the appropriate programing. The intake change to EVO should also help. Since you have the loud exhaust anyway, get rid of the muffler and run a straight pipe or just the 100 cell cats. The car really wont be "that" much louder and again increased hp. I'm assuming you have upgraded your diverter valves and boost hoses to silicon. Changing the FPR and waste gates should also be thrown in!
