Duane's How to Exhaust install
OK gang here it is. A guide to changing the exhaust in your turbo....
These are the tools required:
Floor jack
Block of wood
Jack Stands
13mm wrench
6mm Allen or allen socket
13mm Socket (3/4 or 1/4 ratchet)
Extensions for both (optional)
02 Wrench (22mm) or Crescent wrench (I would rather you use the proper wrench)
<img src="http://Imagineauto.com/porschephd/996TT/tools.jpg" alt=" - " />
Jack the car up from the center of the motor via a block of wood. this is safe, but very important NEVER to jack up the engine without the wood buffer.
<img src="http://Imagineauto.com/porschephd/996TT/wood.jpg" alt=" - " />
Place the jackstands on either side of the car. You should be able to locate them via the markings as seen below on the rocker. Mine is on the lift, but you can see where the pads are underneath the car.
<img src="http://Imagineauto.com/porschephd/996TT/lift.jpg" alt=" - " />
<img src="http://Imagineauto.com/porschephd/996TT/liftII.jpg" alt=" - " />
Next move to the engine compartment. To the left and right of the air box you will see two harnesses as indicated by my pointer. Disconnect the plugs. One simply pinches together the other you pull up out of the bracket and pull the lever back. The plug will separate. Do this to both sides. Now pull them out of the wire clips directly down stream of the wire. They simply pull out of a plastic clip. Remember there are 4 sensors total. Two per side.
<img src="http://Imagineauto.com/porschephd/996TT/02.jpg" alt=" - " />
<img src="http://Imagineauto.com/porschephd/996TT/02II.jpg" alt=" - " />
<img src="http://Imagineauto.com/porschephd/996TT/02III.jpg" alt=" - " />
<img src="http://Imagineauto.com/porschephd/996TT/02IV.jpg" alt=" - " />
Floor jack
Block of wood
Jack Stands
13mm wrench
Next carefully reach up through the bottom of the car and pull the 02 sensor wires out of the side and lower clips. You want to have the wires dangling as not to catch when removing the bumper.
<img src="http://Imagineauto.com/porschephd/996TT/cat02.jpg" alt=" - " />
Now remove the four 13mm nuts surrounding the cats. The cats attach directly to the turbo via four studs. You might want to soak these down with WD-40 or equivalent. The next
<img src="http://Imagineauto.com/porschephd/996TT/turbo.jpg" alt=" - " />
<img src="http://Imagineauto.com/porschephd/996TT/turboII.jpg" alt=" - " />
With all 8 nuts removed, 4 on each side pull the shield around the turbo loose from the studs.
[IMG]http://Imagineauto.com/porschephd/996TT/turboIII.jpg{/IMG]
Working now at the muffler you will want to remove the the tips. Simply loosen the 13mm nut from the bottom and pull the tip straight off.
<img src="http://Imagineauto.com/porschephd/996TT/tip.jpg" alt=" - " />
Looking directly under the muffler as indicated by my pointer remove the 6mm Allen head bolts. This is the main straps to the muffler. I doubt it will go any where, but you may want to have a helper as this thing is very heavy. Once the straps are loose you will need to feed them off of the rear support. Looking up behind the muffler on the engine side you will see how the strap passes over two ears on each side. You will have to work these off of their supports. Now push the muffler back as far as you can off of the studs. Slightly push the cats up over the turbo and pull the muffler out at an angle from the rear.
Remove the 02 Sensors from the old muffler. Notice that the 02 sensors are colored. Black wire goes closest to the cat inlet. The gray wire goes towards the rear or farthest away from the opening.
<img src="http://Imagineauto.com/porschephd/996TT/cat.jpg" alt=" - " />
install on the Fabspeed set up is quiet simple. Place the cats back up there making sure to have the metal oring in the groove of the turbo and the metal shroud in place before to bolt the cat back on. Place the two pipes on either end of the muffler then place the muffler up on the original muffler support. The attachment system is very neat with the Fabspeed. There are two metal plates with studs. Place these behind the support and start the 13mm nuts. You will see what I mean when the muffler is in place. Now take the two clamps and clamp the pipes you placed on your muffler and the cats. Make sure you have both ridges inside of the clamp and tighten them down. Tighten the rest of the clamps, and the muffler down. Now put your tips on. They should slide right over. If not you may need to open the gap of the tip. The inner ring of the tip clamp will need to removed or opened up as well. Plug your o2 sensors back in and hit the key....That's it.
<img src="http://Imagineauto.com/porschephd/996TT/muffler.jpg" alt=" - " />
<img src="http://Imagineauto.com/porschephd/996TT/mufflerII.jpg" alt=" - " />
Ok if all else fails I can assist my son in the install <img border="0" alt="[hiha]" title="" src="graemlins/roflmao.gif" /> <img src="http://Imagineauto.com/porschephd/996TT/tuners.jpg" alt=" - " />
Stephen,
Great post, after all of these years this is the first time I get to see a picture of you (with your chief mechanic)
Hey, at some point you need to try out my buddy Eric's exhaut, is it great. <img border="0" alt="[thumbsup]" title="" src="graemlins/bigok.gif" />
BTW, ignoring the inappropriate, out of place, ridiculous comments from the geek racer....class act. <img border="0" alt="[king]" title="" src="graemlins/r.gif" />
Konrad,
Thanks!! You know me, just not worth it <img src="http://www.c2turbo.com/forums/images/smilies/DUNNO.GIF" alt=" - " /> <img src="http://www.c2turbo.com/forums/images/smilies/toocool.gif" alt=" - " />
CJV,
Ok here is a pic, for those that pass by please no rude commments. This woman has given birth to our two boys and has been with me since I was 13. I am in my mid 30s now. That is a damn long time. This pic was taken 8 months after she gave birth to our youngest Quinn. My son in the picture is four. His name is Jett. Now you know the whole family. They are at the shop with me all day every day...
<img src="http://www.imagineauto.com/porschephd/996TT/roxanne.jpg" alt=" - " />
Stephen,
It was very nice of you to post the informative directions on changing the exhaust.Very nice family as well. It is nice to put your face together with your post.Keep up the good work. Perhaps you could post the pictures of your son changing the exhaust with his sledge hammer?
Rob
Rob
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by PorschePhD:
<strong>LMAO...Oh don't I know it <img src="http://www.c2turbo.com/forums/images/smilies/grinlaugh.gif" alt=" - " /></strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Bloody good show man. I wish I'd waited a few days before having Porsche slap in my exhaust for me (super loud Fabspeed one). It would have been a fun thing to do with a couple of friends. Ah well.. I'll be sure to save that post for future reference (straigh pipes.. cough cough). Your wife has good taste, in cars that is, she's in a Porsche
PS What does your car run in the 1/4mile now, once the smoke clears...
No quarter times yet. The weather here keeps bouncing back and forth. Snows when it isn't supposed to, might be 50 today. I would need to Gtech it at the moment. The strip is closed for the season. Man, do I hate winter <img src="http://www.c2turbo.com/forums/images/smilies/rocketwhore.gif" alt=" - " />
<strong>No quarter times yet. The weather here keeps bouncing back and forth. Snows when it isn't supposed to, might be 50 today. I would need to Gtech it at the moment. The strip is closed for the season. Man, do I hate winter <img src="http://www.c2turbo.com/forums/images/smilies/rocketwhore.gif" alt=" - " /></strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Sorry, I'm from such a small country (England) that when the weather is nice here in California I forget that it's crap just about everywhere else. I have the new G-tech and it's pretty sweet...
