Revamping Modifications - CJV, any final suggestions?
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
I dropped my car with Bobby Singh (a Unichip Dealer) of Manhattan Motorcars to install the GUARD Gears & Synchros, exhaust (deciding between RUF and Fabspeed,) K24 turbos, sachs clutch, H/R coilovers at GT2 height, Unichip DEFI Boost and EGT guage, C4s Chin Spoiler, GT2 Intercoolers, GT2 wing with ducts, a stronger Front Diff., and have it Dyno tuned.
Now CJV, Can a program like yours be installed on mine without dynotuning? My setup is very similar to yours, so just wondering. Also, would it work even if I decide to go with the Fabspeed exhaust?
Thanks in advance
Thanks in advance
CJV,
I already have the B&M Short Shift kit. With the Single mass flywheel, do you get clutch Chatter? In my Supra, the light flywheel makes a "Clacking" noise that is annoying at idle if the clutch is not depressed.
Would you suggest intalling a programmable shift light since the car will hit redline quicker?
Thanks for all your help,
Shank
Shank
CJV,
After intensive internet searches, I found this shift light by SPA <a href="http://www.spatechnique.com/shiftlight.html" target="_blank">3 Stage Programmable for $160</a>
This is the same one Gemballa uses - here are the pics - they neatly drilled it into the dash:
and
![](http://www.rshankar.com/gemballa/images/G96_GELB_TGTR_650_20.jpg)
and VS: Supposed to be a comma after "UNICHIP, ..."
![](http://www.rshankar.com/gemballa/images/G96_GELB_TGTR_650_19.jpg)
and
