Want to upgrade to Ceramic Composite Brakes (PCCB)
"What do the big brembos run?"
you can go 14" front and about that in the rear in the two piece alum floating hat rotors for sub $6k. the weight diff is about 10 lbs. between these and the ceramics. there is another brembo setup which is actually lighter than the ceramics and runs under $10k.
