Just had my car dynoed with a DynoJet 248c. I did this as a before prior to installing the mods.(as we speak). 474 was best and 461 worst (heat soaked). This with stock programming EVO V-flow and Europipes. HP is altitude adjusted (SAE). I am in shock. Also my Mechanic (Orrin...thanks much) says it was running lean (there was more there). I will get the sheets when I pick up the car Friday and post.
This is on the OEM computer programming?? I assume it was on a RWD dyno and the numbers are adjusted to FWHP? If so, what correction factor did you use?
