Speedo Question
I asked this question before and everyone said it was normal....but my speedometer works fine but the indicator in the tach does not match the speedometer. It does like an average speed and is nowhere close to the actual speed. I am almost sure that when I first bought my car that they were both the same and you could check your speed from either the tach or speedometer. Could someone check theirs and let me know if I am correct? Also the MPG does not seem correct either. I do have extended warranty and need to have this checked if it is not working correct. I did ask dealer about it and they said it was working correct.
I run it pretty low as i do not drive this car very much. I am talkig about the setting that tells you how much MPG that you are getting while driving. When i first bought it it would say like 25 MPG when in high gear and now shows like 15 MPG. It does not seem correct to me.
I agree with Doc, the Digital readout will go much higher than 200 mph, whereas the analog
dial stops at 200. Remember in a blistering fast acceleration run, the digital readout often
cannot keep up with actual speed (it lags behind). This is one of the many reasons the
speedometer cannot be used as the (60-130mph) indicator--it simply is not accurate enough.
Marty
Marty
The bottom line is the system is not real accurate, especially if you run the gas below 1/4 tank.
