996 Turbo Forum 1999-2005
Clutch Problems
Old 10-03-2005 | 12:57 PM
NC Bob's Avatar
NC Bob
Default Clutch Problems
Got an '02TT with 29,000 miles. Noticed last week that the clutch pedal would slightly bind just about where the clutch engages on pedal travel. Also experienced a slight pedal vibration as the pedal reaches maximum travel at the floor. Clutch does not appear to be slipping. Now what I'm getting is a hard pedal after the engine is shut down. Seems the power assist bleeds off after just 2-3 minutes. Once the engine restarts, clutch appears to act normally with the exception of that vibration at the end of pedal travel. This disappears after a few minutes. Any ideas? If there is an easy fix to this, I'll do it myself. If not, into the dealerit goes.
Thanks.
Old 10-03-2005 | 09:29 PM
ebaker's Avatar
ebaker
Sounds like the check valve in the slave cylinder is leaking. There was a thread on it in May or June.
Old 10-04-2005 | 08:28 PM
t urbo's Avatar
t urbo
Check out the Clutch Accumulator post!
Old 10-05-2005 | 10:35 AM
NC Bob's Avatar
NC Bob
I did. Very helpful. Even my service advisor learned something.
Many thanks.
Quick Reply: Clutch Problems
