Pagid pads wont fit with shims in place
Just fitted new pagid pads to the front of my 04 tt (tight fit), but the rears wont go in with the shims in place. Will it be ok to track the car without the shims then refit them once the pads have worn abit?
Still plays with cars.
You can leave the anti-squeal shims out. After a few days of tracking reinstall if you wish. They do reduce squeal quite a bit. Are these Pagid RS19 Yellow by any chance? They are endurance racing pads and are a bit thicker than street pads. I had the same problem on my GT3.
Rgds
Rgds
OK......just wanted to be clear you were not trying to fit them both in together at once (shim & pad)......personally I've never had a problem (on the 996turbo or 993) of putting Pagid Orange (44s) but I have yet to try Yellows.....they may be a tad thicker.
