Real world numbers on new Intake for TT
My Gruppe M cone style intake complete with its cold air "ram" style intake lost 10hp on RS Tuning's engine dyno on my 993tt compared with the stock air filter set up. A GT3 stye cone had the same results. Apparently the Gruppe M 996tt cone ram air filter gives the same sort of losses. Why would your filter give the opposite results on a 996tt
Rennlist Lifetime Member
For several reason such as the design of the intake pipe. It increases velocity with the 6 inch venturi on the inlet. Also your filter is in the back of the motor. This is not. The two systems are no where near the same in regards to feeding the turbos. If I also recall the inside of the Gruppe was not finished off which would cause turbulence.
just opened rear deck lid looks like quick hp esp the cold air part have simiular on 86t sounds neat but sucks hot air. just ordered for the 01 tt can't wait !!!!!!!!! 86 is for sale steve
Stephen - The lower horizontal edge of the air filter "box" doesn't appear to have any rubber seal associated with it. What keeps hot engine air from being drawn in from this area below and behind (towards the back of the car) the air filter?
You are correct there is no seal in this area. That area is rather tight. While some air may get in there, the amount is certainly overcome by the amount forced down the inlet channel.
