Too Much PSM?
Too Much PSM?
I went driving on a wet track yesterday, tires not so great- Potenza SO2 - they are not R rated.
PSM came on a great deal, especially in exiting high speed corners, fast launches, etc.
Is this normal? Do i need better tires? Normally, I can drive under these conditions at the track without the need of articifical traction control aids. But this is my first 996 Turbo X50. Is this normal? Am I bad driver?
Any comments? Thanks in advance.
02 996TTX50
92 RSA
93 911 Turbo S2
80 SC
02 996TTX50
92 RSA
93 911 Turbo S2
80 SC
RSA, this is a great article that explains how PSM works in Porsche's:
http://webdisk.berkeley.edu/~dlrowney/PSM.txt
I hope it helps !
I hope it helps !
RSA, are you comparing your experiences with the Turbo to your past experiences with other cars? The Turbo has a tremendous amount of torque. At the Nürburgring (not a lot of traction in the wet), if I floor it on a straight in the lower gears then PSM will intervene. It is necessary to feather the throttle and feel for the point where the tyres are losing traction. Race tracks can actually be worse than regular roads because of all of the rubber on the surface.
So it wouldn’t be surprising if you are able to get the PSM to intervene coming out of slower corners in an X50 car if you are using full throttle.
Do you need new tyres? Tyres are obviously the limiting factor. Impossible to say whether they are substandard and need to be replaced or not. Only you can really judge that.
Stephen
Stephen
Thanks...
Bougeron and others -
Thanks for the feedback. The link provided really offered some good advice on its use and non-use in road racing, which is the majority of what I do. I realized that my normal ability to throttle steer and using brakes to modulate car movement were being hindered by PSM, and in some corners, I may need to turn it off. Also - I am used to RWD 911s, and that could have been part of the problem. Power is no longer the issue, I just need more seat time and learning new habits.
Thanks - Gerry
02 996TTX50
92 RSA
93 911 Turbo S2
80 SC
Thanks - Gerry
02 996TTX50
92 RSA
93 911 Turbo S2
80 SC
This is the big handicap of the Turbo on the track.
Stephen
