turbo rear spoiler
6th Gear
hello all, new member here with a question i hope someone can answer. How do you remove the rear spoiler on a 996tt ? if anyone has done an upgrade or swap i would greatly appreciate the info. To clarify i am refering to the upper section the raises/lowers
thanks
RG
thanks
RG
Rennlist Lifetime Member
You will need the tool to unlock it. There is a hole in each arm. Once you raise the spolier you will see the hole. You need to make or buy a toll to latch into the hole. It tool looks like a fan tool for an old 911. Lock the end of the dowel or tool into the hole and simply unlock the latch. It moves about a 1/4 of the way then frees the spolier. Thats it. Careful not to slip you will hit the quarter if you do. It also helps to have two poeple helping with this.
I prefer Stephen's hand-made Tool
It's ghetto-looking but works a treat!!!! I still remember using it on the Roock spoiler we used last year.
6th Gear
thanks for the good info, i knew the little hole had something to do with it. Looks like i'll have something to do this weekend. On my way to fabrication area to make myself a "special" tool
