Alignment Help
Alignment Help
Taking the TT to Hergesheimer today for an alignment. I'd like to reduce the understeer a bit. I'm leaning towards -1.5 degrees camber in the rear and -1.0 degrees up front. This worked pretty well on my C2. Will -1.0 in the front be possible with stock suspension?
Keeper of the Truth
Whether or not - 1° camber is possible up front depends on the vehicle. Some are able to get it from the stock suspension, some aren't. I'd say, you have a 50/50 chance.
