New Group Purchase – 4 Post LIFTS!!!
In honor of the upcoming Labor Day holiday, X-Auto Products is offering special discounts on all sizes & specifications of automotive and Cycle/ATV lifts. We feature the finest brand of lift on the market - the Revolution Lifts by Rotary. Rotary is the world leader in commercial & industrial automotive lifts. No one builds a stronger, safer and more durable lift for the automotive enthusiast. If you've been wanting a lift for your garage, then now is the time to consider placing an order. Get a jump on the holidays by taking advantage of these extra low prices, and special payment plans for Rennlist members and visitors. But don't wait. This offer will end on September 7th and will not be repeated.
NO OTHER LIFT MANUFACTURER builds as much quality into a lift. All Revolution Lifts are built to meet the requirements of the Automotive Lift Institute. Each design is tested by the ETL, an OSHA-designated nationally recognized testing laboratory, to ensure compliance with ANSI standards ALCTB-1998 and UL Standard 201. In fact, each lift comes with its own certification label to ensure you that your lift is up to the job. The 4-Post Lifts are rated for up to 7,000 pounds, have 110v or 220v motors, and come in a choice of colors.
· 4-Post lifts come in standard length and extra long. Allows two cars to park in one garage space. A complete line of accessories will make your lift work even better.
· Mid-Rise lifts work with ceilings as low as 9 feet. Some models mount to the floor, others are portable. All Mid-Rise lifts can be operated outdoors.
· Cycle / ATV lifts have up to a 1500 lb capacity to handle the biggest Fat Boy or monster ATV.
X-Auto Products is making sure you get the best lift for your money. And, we're making it easy to get one without busting the budget. You can:
· Give us a 100% refundable deposit to hold this offer and schedule delivery later this year
· Pay in full and get your lift right away
· Set up installments and pay it out over 5 months with no fees or interest added. Your lift will be shipped upon payment-in-full. And, if you change your mind, you get 100% of your installments refunded to you.
Lift Models & Pricing -
4-Post Lifts – There are two models (standard and XLT) and two power choices (110V & 220V). Our Labor Day pricing is $2588 for the standard lift and $2788 for the XLT model. There is no difference in price between the 110V & the 220V motor. The accessories are priced as follows:
· Drip Pan Kit - $168
· Drive-Thru Ramp Kit - $188
· Caster Kit - $638
· Low Ground Clearance Ramps - $238
· Jack Trays (jacks not included) - $138
· Solid-Top Decking - $1088 for standard, $1288 for XLT
· Shim & Bolt Kit - $58
THINGS TO CONSIDER
The following things need to be taken into account before ordering a 4-Post lift (these do not apply to Mid-Rise or Cycle/ATV lifts):
Ceiling Height -
In order to ensure that you have adequate room for a 4-Post lift, you’ll need to consider the following parameters:
A - the height of the car you will store on top of the lift (consider using the tallest car you have just in case),
B - the height of the car you will store on the bottom (consider using the second tallest car you have just in case),
C - the height of the lift runways the upper car will rest on - use 5 inches,
D - the MINIMUM distance between the garage floor and the LOWEST obstruction that the upper car may interfere with (such as garage door tracks, a garage door opener, lighting, shelving, etc.).
When calculating your ceiling height, simply add A+B+C, then add another 6 inches to allow for the lift to be raised high enough so you can safely lower the lift back down to engage the locking mechanisms. If the total of A+B+C+ 6 inches is less than D, then you have enough ceiling height to accommodate a 4-Post lift with the vehicles you’ve used for establishing the above parameters.
Delivery -
Although the shipping charges will get the lift delivered to your house if you like, you will likely be far better off to have it delivered to an interim receiving facility with the appropriate loading docks and equipment. This is due to the fact that the shipping weight of a 4-Post lift is 2100 pounds, and it will arrive at your house awaiting a forklift to get it off the truck. The solution is for you to use a trailer to pick up your lift at the receiving facility where their forklift can properly load the 15’L X 3’W X 4’H container onto your trailer. Then, it is a fairly easy task to unpack the lift components and move them into your garage for assembly after you arrive home.
Shipping charges are $200 per lift regardless of model. Shipping charges for accessories total 8% of the accessory price. More information about the designs, specifications and other details of these Revolution Lifts can be found at www.x-autoproducts.com. Or, as always, please feel free to call us 800-559-1192 to discuss things in detail. Thank you.
Barry
X-Auto Products
· Caster Kit - $638
THINGS TO CONSIDER
Ceiling Height -
Delivery -
Barry
X-Auto Products
stoked944
the lift market is very competitive, and there is zero margin in the products for distributors like me. that said, i believe the Revolution Lift to be the best on the market, thus it commands a higher price than some others.
so, my discount gets it close to the prices of some of the other lifts you may be considering, but i believe the difference in build quality to be worth the additional cost. just looking at the weight of the Revolution 4-Post Lifts compared to others tells you the Revolution Lift is build to be stronger as it outweighs some other units by a few hundred pounds!!! that's a material difference, and that's one reason why they cost more.
so, you may think the discount is small, but in actual dollar terms, i believe you'll find these lifts are far superior, and the discount makes the pricing very competitive.
thanks for the note. please call me if you have any questions.
regards,
barry
X-Auto Products
800-559-1192
regards,
barry
X-Auto Products
800-559-1192
