I haven't sent them out yet. I've been doing wastegate research and talking with Sam. Ordering some Turbosmart wastegates soon.
I don't have the specs but i will be going with a larger billet compressor wheel and improved exhaust wheel (most likely Mamba) via Evergreen.
Sounds good. The larger wheel will give you all the boost you need and hopefully the Mamba exhaust wheel is lighter and more efficient resulting in quicker spool up time. All you need is the 18G sized compressor unless you are going really crazy with it.
It would be interesting to see what a K16 could do with the 18G sized compressor and the larger exhaust wheel. That might slow it down a touch and give better top end, might be a good option.
vtec_
close
- Join DateJul 2021
- LocationNew Jersey
Liked:513 Times in 421 Posts
Quote:
If I still have a job come January, I am probably going to pull the trigger on having billet k24 compressor wheels and a k24 turbine wheel milled into these old k16s i got.Originally Posted by Bernard IV
otherwise ill just have to settle for maybe clipping the k16 turbine and getting a tune until things get better..if that ever happens.
I found an original set of GT28s in k16 housings for cheap that is kind of tempting..
T10Chris
close
- Join DateDec 2015
- LocationBellevue, WA
Liked:558 Times in 405 Posts
At a certain point shoving these higher flowing turbine wheels into the little housings will cause its own issues, you'll notice it first with boost control not doing what you want. It's a balancing act, especially if you don't intend or want to build a motor, the limits of the stock motor can be easily reached with the existing compressor/turbine combos...
vtec_
close
- Join DateJul 2021
Quote:
boost not being able to hit targets due to wonky flow characteristics or hard to modulate at lower rpms?Originally Posted by T10Chris
It seems the stock k24s are good for about 550 WHP with the right supporting mods.
I've been reading about some setups where they used the EMAP pressure to control the wastegates.
I think he's saying the wastegate opening might not be big enough and you would wind up with boost creep.
ExploreBurning Brakes
Quote:
how does it connect to the N75 valve (assuming the audi uses one?) which i think they do..
-3AN. Wastegate lines both go into a Y. The unused Y port had a barb fitting that went to the N75. I think it cost me like 50 bucks to make.Originally Posted by vtec_
got specs on those AN lines/fittings for the WGs? @Celisonhow does it connect to the N75 valve (assuming the audi uses one?) which i think they do..
EDIT: JK, make that $130.
