Coil Overs
Customer support has, so far, been very good - I did a full refresh with top mounts/camber plates front and rear, swift springs, rear extenders.
Shop induced problem is steering wheel is skewed left, and has a **** on center (vague) feeling - I suspect this is due to a little less toe than I'd like, and most certainly a degree less of camber than I'd like, but this is in no way the fault of BC.
I have not even moved the says from their softest setting, so yes, not too shabby so far.
Feals and BC are not rebranded anything. D2, Gecko, etc. are all rebrands. As far as I can tell every street-focused coilover has had issues, Ohlins, KW and Bilstein included. I have also seen a lot of people that don't know how to set up coilovers, buy cheap coilovers and then complain they ride like crap. I have Ohlins on one car, BC on another car and a stack of swift springs. Learn how to set up your suspension and you'd be surprised how well your car can ride and handle for any specific use case at every budget point.
I'd rock the BC, FEAL, or Fortune Auto stuff before the XYZ, Yellow Racing, etc. ebay stuff for sure. I still try to put the best parts I can afford on the car, it's a Porsche.
I had considered doing something fancier, but, I drive it year round, bang for buck not bad, don't think the soobie is worth much more.
you can interpret my comment how every you want. Most people don't know how much suspension travel they have based on their rod stroke, spring stack height, preload and ride height. If you do know, great, good for you. But for street driving and rando HPDE a well set up Feals or BC DS won't underperform Ohlins.
IMHO you can't really say this categorically. If the car is run at an HPDE at track where curb cutting is part of the "preferred" line than a skilled driver will feel the difference between coilovers.
This, absolutely.
I've just gotten back from a 3800km trip, and I ran fairly hard, but having a super fancy coilover on the road would have been impossible to get benefit out of, but it would have likely beaten me to a pulp if it were.
The Ohlins have a progressive dampening profile dual valve or whatever it is. That's why it is able to give a smoother ride, it has a bit of soft cushion before it gets into the firmer dampening on the shock. With the non adjustable coilovers you just get a linear dampening profile so as long as it is set up properly the handling is probably the same.
I do believe the BCs have something similar, cannot recall it's trade name.
In the STi, they ride a lot smoother than the gymkhana setup they replaced, just have to sort the last alignment issue to give proper feedback.
Also BC has the DS coilovers with digressive valving, this is exactly what I have. I also have custom Ohlins RT on my other car. Street driving and random HPDE neither is superior than the other in my hands.
https://bcracing-na.com/series/ds-series/
A skilled driver that cuts curbs is not doing a "rando HPDE", which is why I say a daily driver and rando HPDE, amateur's aren't hitting curbs.
I had JRZs on my car and then switched to FEALs and I can tell you as good as FEALs are they do not performs as well as the JRZs.
I recently installed some Feals 441+ coilovers onto my car. If your looking for something that rides well that will increase the handling over the stock worn suspension they are really great.
I was expecting a much harsher ride with these coilovers but they are maybe just slightly harsher than OEM. I highly recommend them.
You are making a lot assumptions. I am an amateur driver that has done plenty of rando HPDEs and at Watkins Glen and other tracks I cut curbs every lap because that is the "proper" line through those corners.
https://www.youtube.com/watch?v=ZwZhfCXLUdU
