DDIN -DIN conversion for GT3 console delete
I recently removed the big box style DDIN OEM radio/nav unit from my dash and am trying to install the HVAC and the aftermarket Continental unit in the upper dash. The information is all over the place on this topic.
I already contacted Bergvill in Norway and he does not have any connectors for this.
So here is where I’m at:
I just installed the GT3 center console delete on my ‘01 996tt. Moved the HVAC wires up and now I need to plug in the Continental radio I bought.
Two problems I need to solve are:
1. How do I connect the radio? (See OEM connectors in photo)
2. How do I mount everything? The $30 Metra kit off Amazon doesn’t work. Even after I pulled out the big square metal frame. It looks like its for a Boxster and not a 996.
you will need the factory cage that goes in the upper dash... the climate control will go in the top spot with the radio underneath it...
as for the wiring, did your car have premium sound? because there would have been a separate controller that went into the lower dash that might need to be plugged back in with an oem unit... bypassed for aftermarket. check the harnesses you have available. what car is the headunit from?
no premium sound. The missing plug is the B plug from the radio diagram. I don’t have that. Everything else plugs in aside from the nav system connections.
what exact frame works with a DIN setup. I pulled the old metal one out.
Also there was a ground connected to it, do you know what that is?
You will need the proper harness adapters from Amazon or local car audio store if one still exists. I think walmart sells the adapters too ( vw/audi work fine). I would spend some time on the threads on the 996 forum on stereo upgrades on here. I also have a thread in here around the Ali express pccm clone that covers almost every permutation of wiring we have come across.
https://rennlist.com/forums/996-foru...n-here-36.html
https://rennlist.com/forums/996-turb...s-install.html
amazon stuff you will need depending on most or non most car. antennae adapter and stereo adapter
I gotcha it goes up top. I just have that HVAC thrown in there right now.
https://www.pelicanparts.com/More_In...231-11-01C-OEM
the ground wire you see there is a disable for the factory radio antitheft...
if you are missing the B-plug for the speakers,, it might be because you have a factory amp in the frunk... that means radio goes to amp and amp to speakers... do you have RCAs in the dash? you might have to try and source a missing B-plug and wire it up yourself
The HVAC was in front of the shifter. I just set the climate control in there for the time being. The problem is I don’t have the mounting bits and pieces to properly mount it.
here is the support frame you need... normally when you install a double DIN, it tells you to dremel out the middle section... this has the cage for you to properly slot the HVAC controls up top and radio in the bottom...
I replaced my CF ashtray with the optional bin and painted it to match the shifter U shaped trim to break up the CF a little bit.
That's what mine has. I would not be surprised if it was more than $3K. I was referring to the front part where the console used to be. I don't believe that is a factory part?
When I do this there is power but no sound.
When I don’t use the harness and just plug in the radio, same thing there is power but no sound and since I am not using the harness I have no brown plug👇👇👇
Bergvill in Norway just sent me this:
We have done several attempts to make a harness for use in PCM-equipped vehicles.
As far as we know, does the PCM head unit communicate with the amplifier by means of a digital interface. We have no idea how to replicate this communication, and the Continental units certainly have no possibility for this.
There may be several types of PCM units, and some of them may not have this communication system.
However, the expected sales numbers of a harness would be very low, maybe one or two per year. Very, very few people want to change from the 2-DIN PCM to a 1-DIN type of head unit.
Anyway, we have too much time on this, and have abandoned the idea of a harness.
I am therefore unable to help you in your endeavours.
Any ideas? Anyone happen to know of a DIN radio that just plugs in?
i think you can use something like this?
https://www.ebay.com/itm/37368966800...Bk9SR4rW_sDPYw
otherwise you will need to find a junk dismantler and get them to cut you a harness off a car... then run the speaker leads to the amp in the frunk...
are you sure you don't have RCAs in there? they would of had to pull the speaker output from one of the harnesses... what radio did you have in there previously, can you take a pic of the back?
