996 Turbo Forum 1999-2005
Changing the Pss9 setting. Easy ?
Old 06-12-2004 | 11:00 AM
boqueron's Avatar
boqueron
Question Changing the Pss9 setting. Easy ?
Here is my very last questions concerning settings to Pss9 users before ordering a Pss9 set for my TT :
I plan to shift settings from my daily use to occasional tracking days. Is it easy to change them ? Is it really a DIY thing ? How long does it take and which specific tool ( if any ) is needed?
I understand that changing the settings ( without altering the heigth )should not force to change cambers, alignment,corner balancing, etc...
Old 06-12-2004 | 11:54 AM
msindi's Avatar
msindi
should be easy - for rears you do it from inside car, if you have a bose sub that needs to be removed first.
The fronts are done fron under the car/behind the wheels...
Old 06-12-2004 | 01:06 PM
boqueron's Avatar
boqueron
Thanks msindi, have you ever done it your self ?
Old 06-12-2004 | 01:57 PM
msindi's Avatar
msindi
not really...i assure you it is easy from what i am told
Old 06-12-2004 | 02:05 PM
ryce's Avatar
ryce
Its pretty easy; I've done it myself. On the rears, you pull the bose sub wiIth a torx driver, pull away some sound insulation and turn the dials. In the front, you do it from under the car. It was easier to turn the front wheels full left lock to get to the right shock and vice versa. You pull the rubber covers off of the adjustment ***** on the bottom of the shocks, change your setting and put the rubber boots back on being careful not to alter the settings. It should take 15 minutes the first time.
Old 06-12-2004 | 05:48 PM
boqueron's Avatar
boqueron
Thanks Ryce. Sounds easy.
