Preparation for August 9th Thunderhill Porsche PDE
This one should be fun... I figure there will be less cars than usual out on the track that day if it's a Porsche only event....
Thanks for setting it up Fred.
You could flush the brake fluid with high temp stuff like ATE. If you don't like the feel of your brakes you could swap pads for something with a bit more bite. I think Thill also has high octane fuel. You could time it so your tank is nearly empty when you get there and fill up on the high octane stuff. Bring a torque wrench and check your wheel bolts before every session. Basically the same stuff you did with your 300zx.
Thanks !! So, ATE is the brake fluid replacement of choice for high temp situations ? Sorry for my ignorance, but do you have an explicit description of the brake fluid (full name, or is ATE sufficient?) Just like Motul has a bunch of lines, I'd like to know what is recommended specifically for the 996TT's.
Similarly, the brake pads.... what are the recommended ones and trade-offs advantages.
Thanks,
Andy
P.S. Yes, T-hill does have 100 octane, at least the last time I was there (2001). The last thing I want to hear is detonation, so I look at the 100 octane as 'insurance'.
Thanks,
Andy
I just mentioned ATE as a generic example of high temp brake fluid. You know Motul, and I've never hear of problems in Porsches with it, so you may as well use something you're familiar with.
As for brake pad specifics, you'd probably find your answer in a search.
GT3 player par excellence
yes, ATE is enough description. if the shop don't know it, you should run from that shop asap.
motul 600 and AP racing fluids are both fine. i used all three types with no prob in 993, 996.
i think in general you want more advanced timing until you reach detonation pt. higher octane will be harder/slower to detonate. so hi octane fuel should allow more advanced timing, in theory anyway.
I agree with your theory. My question was maybe a misinterpretation of the previous post. I was wondering if the 996TT had an octane detect->change timing algorithm somewhere.
It would be contrary to what I would think would be what you would WANT. Higher octane=more stable fuel=less likely detonation therefore, you can probably be more aggressive with the timing.
That was why I was asking.
ah, gotcha.
