996 Turbo Forum 1999-2005
Anyone have an EvoMS airbox kicking around?
Old 07-26-2023 | 04:37 PM
s65e90's Avatar
s65e90
Originally Posted by 2fcknfst
Does the gold foil aid in keeping the air charge cool?
The BOV - is that set up for sudden lift to avoid overboost? That's pretty cool, I use those on diesels, curious to know how they work on the turbo.
Yes, gold tape is a very good heat shield. Our cars use bypass valves, just recirculated back into the intake. This is just an HKS valve. It's loud and vents to the atmosphere. You can vent them running the mafless tunes.
Old 07-26-2023 | 04:38 PM
2fcknfst's Avatar
2fcknfst
Very cool; opens between shifts and when you lift?
Old 07-26-2023 | 10:37 PM
s65e90's Avatar
s65e90
Yes, similar to stock, just not recirculated and one versus two, plus it's much louder. The HKS is also a pull versus push valve.
Old 07-27-2023 | 02:16 PM
sdematt's Avatar
sdematt
Originally Posted by docwyte
That looks super cool! How'd you make that molded inlet duct?
Agreed - where'd you get/make this?
Old 07-28-2023 | 02:34 AM
powdrhound's Avatar
powdrhound
Manthey racing used these on their high hp builds. This is commonly referred to as the Mathey intake. A friend of mine makes these in Germany in his factory at the Nurburgring. Not cheap but very elegant and we have shown gains on the dyno. Probably not worth it unless you open up the intake pipe first and are above 700whp.
Old 08-07-2023 | 06:23 PM
kentburlingame's Avatar
kentburlingame
I have one sitting in my garage somewhere if you're still looking for one (burnt out far too many Bosch MAFs and decided to just go back to stock airbox, so it's lightly used, but may be a bit dusty). Not sure whether it has all the pieces you'd be looking for (I don't recall the mesh air filter cover you can get with them), but the box itself, the filter, and the rest of it should be there. Can double check later today or this week and send along details.
Old 08-07-2023 | 07:24 PM
docwyte's Avatar
docwyte
I am still looking for one, I'll pm you
