Power spring at pedal / trick to install it?
Per the subject , the power spring on my car was removed a while back and I came cross it again while inspecting for a clutch master cylinder leak…. and went to install it. Is there a way to install it properly with the clutch pedal still installed? The pin that retains it needs to seat in a hole where there is no clearance to put the pin in. My only other thought is remove the instrument cluster and get to it that way? Thx
