996 Turbo Forum 1999-2005
WTB Wing spanner wrench
Old 10-10-2022, 10:50 PM
jcc0016
jcc0016's Avatar
Default WTB Wing spanner wrench
Any one have a spanner wrench to remove the rear wing they are no longer using?
Message me if you have one to sell. Thanks
Old 10-10-2022, 11:43 PM
Capt. Obvious
Capt. Obvious's Avatar
Received 1,450 Likes on 793 Posts
You can use an allen key to remove it as well.
Old 10-11-2022, 06:06 AM
jcc0016
jcc0016's Avatar
Do you by have a picture of what you’re referring to? Thanks for your help.
Old 10-11-2022, 10:54 AM
FRUNKenstein
FRUNKenstein's Avatar
I bought mine directly from Dave at Rennkit. This is what it looks like:
It appears that Dave no longer sells this wrench, but he does have a more expensive model for $50. If that's a bit rich, here's one on Amazon for $25. Looks like 2-day delivery:
Amazon Amazon
Hopefully you need it because you are installing a set of eRams. I have two 996TTs, both with the Rennkit eRam kits. Fantastic product and truly an upgrade, not just a repair.
RennKit-Dave (10-12-2022)
Old 10-11-2022, 11:29 AM
jcc0016
jcc0016's Avatar
Thanks for the Amazon link. I had searched there yesterday and did not see one. Order placed!
No, not installing an eRam kit yet as my car only has 40K and the hydraulics still operate well.... although I know its only a matter of time. I am going to try out a Misha GT2 blade and see how I like it.
Old 10-11-2022, 11:33 AM
s65e90
s65e90's Avatar
That's basically a coilover collar wrench.
Old 10-11-2022, 12:24 PM
Capt. Obvious
Gently rotate the piston until the holes in the chrome part and the brass part underneath line up then insert the short end of the largest allen key you can get in there (3mm I think?) then you can use that for leverage to turn the assembly to release the wing.
Old 10-11-2022, 01:10 PM
jcc0016
jcc0016's Avatar
Essentially yes, but the "pin" seems to be of a smaller diamter and the coilover wrences have a rectangular pin and was skeptical that it would fit.
Old 10-12-2022, 11:20 AM
911 Rod
911 Rod's Avatar
I used a punch of the same diameter.
Old 10-22-2022, 03:47 PM
Chris996
Chris996's Avatar
Turn the silver tube by hand until you see the inner hole. Insert alan key . Just place a key in the hole / inner and grab silver tube with hand and turn 1/4 ++ to detach from wing.
keep the wing up: if working raise the wing. Insert towels to keep the wing max height. If not working just lift with hands. Rip out all the hydraulic. insert a metal rod 2.5 inch into the bottom of the hydraulic. This is where the hydraulic line connects to the tubes L/R. Insert screws to hold pin in place. Wing is always up and leaking hydraulic out.
add extra inch to heigh: one of the tubes have a limiter with in. Open up the spring loaded tube. Insert extra pin above the factory inner pin. Re assemble and install as above.
Always up / extended extra 1 inch
Quick Reply: WTB Wing spanner wrench
