996 Turbo Forum 1999-2005
350mm rotor upgrade
Old 07-07-2022 | 02:29 PM
  #46
2jzhx60's Avatar
2jzhx60
Originally Posted by Djbrand1
Any spacers get turned out from this effort? Still trying to track down a set. Thanks!
My friend who made them for me have these along with longer bolts. Send him an e-mail or DM on instagram:
https://instagram.com/kenaxbillet?igshid=YmMyMTA2M2Y=
Old 07-08-2022 | 11:11 AM
  #47
pfava1's Avatar
pfava1
Hey, I drew up these plans, and had a buddy of mine make them for me. He is a machinist for the Nat Guard. Let me know if you want a set, he did mine for 200.
Old 07-08-2022 | 11:29 AM
  #48
2jzhx60's Avatar
2jzhx60
Thanks for drawing these. Did you notice the error on the bolt holes in the rear? Would be good to correct it. So its 130mm and not 131mm.
Old 07-08-2022 | 12:14 PM
  #49
pfava1's Avatar
pfava1
Noted.
I was playing around with tolerances in these. I can issue an update, that's why you see the different size in the bolt hole, the 12.5mm vs the 12mm I had written with the fronts. In the new plans I'll stick with the 12mm and 130 spacing. I installed this setup in my car per plan spec and it fits fine, but if I make another I'll so the 130 and 12mm with the rears.
2jzhx60 (07-08-2022)
Old 07-08-2022 | 01:17 PM
  #50
Djbrand1's Avatar
Djbrand1
Thanks 2jzhx60, I reached out to him on Insta.
Old 07-08-2022 | 03:30 PM
  #51
pfava1's Avatar
pfava1
let me know if you want a set, we just milled these
Old 07-08-2022 | 03:41 PM
  #52
2jzhx60's Avatar
2jzhx60
Here's the Kenax ones:
Old 07-08-2022 | 03:42 PM
  #53
pfava1's Avatar
pfava1
they nice!!!
Old 07-08-2022 | 08:24 PM
  #54
Third-Reef's Avatar
Third-Reef
With the 350mm rotors you should have more stopping power for the same pedal pressure as the frictional force is being applied at a larger radius. If I did not already have a BBK on my car this is what I would be installing.
Old 07-12-2022 | 01:10 AM
  #55
Djbrand1's Avatar
Djbrand1
PM'ed you. Thanks
17ram2500 (04-10-2023)
Old 04-10-2023 | 06:58 PM
  #56
17ram2500's Avatar
17ram2500
Thanks to pfava1 who still had a set in stock. Just bought a set for my car. So nice to have guys here to help!
Quick Reply: 350mm rotor upgrade
