ssk B&M
ssk B&M
please someone.,-need help in adjusting the ssk.it feels tight getting into 5/6 gear,can someone pls give me instruction on adjusting it.have played around with the blue n black spring thingy-should the travel distance be shorter or longer.did not reinstall the stock square plastic bushing on the side pivot ball on to the b&m-is this correctly done?your advise is appreciated.
I think you need the stock square bushing on the side!!! also, only the passeneger side cable (blue if memory serves) is the one to adjust for forward gears...other one is only for reverse...
