Brake Pedal Vibration At Low Speed
#31
Totally understandable. Will report back if I find anything.
In the other thread someone pointed me to this which might be related: https://www.6speedonline.com/forums/...ow-speeds.html
Wow, that thread at 6spd makes it seem like this is a pretty normal occurrence by some of the posts.
#32
Ryan did you ever figure out what this was and what the fix is? I'm experiencing the same thing.
When I got my brake fluid flushed, they said one of the pistons was starting to stick and might need a rebuild. Would that be causing these symptoms?
