996 Turbo Forum 1999-2005
Mr.Snail's 2001 Guards Red 996TT Ownership Thread
Old 04-07-2021 | 01:15 PM
  #106
Mr.Snail's Avatar
Mr.Snail
Originally Posted by diverzeusy
ok, why have you changed your fuel pump? Old one broken?? I'm told the OEM pump is good for 600/650 bhp??.
I'm asking because I'm on this journey, and my 21 year old pump is working fine, I'm keeping the STD fpr, but installing bigger injectors, 16/24 billet hybrid turbo's, gt2rs intercoolers
Should I be changing my fuel pump, even if just for piece of mind 🙄🤔
Thanks 👍
My tuner Sam indicated i was running out of fuel, (completely stock fuel system) on maffless stock k16 set up. He recommended the new Radium Walbro pump set up. We are re-tuning it now and after the first review it appears we are heading in the right direction.
diverzeusy (04-07-2021)
Old 04-07-2021 | 08:34 PM
  #107
diverzeusy's Avatar
diverzeusy
Capt. Obvious & Mr Snail, replies duly noted, Walbro pump ordered 👍
thank you 🇬🇧💕🇺🇸
Capt. Obvious (06-16-2021)
Old 06-12-2021 | 10:00 PM
  #108
Rapid-911's Avatar
Rapid-911
So replacing the stock fuel pump to Walbro, do you need to retune or will the car just work? I assume just work as excess fuel returns to tank.
Old 06-15-2021 | 08:05 PM
  #109
diverzeusy's Avatar
diverzeusy
i don't know 🤔 my thoughts are the Walbro pump just moved more fuel faster with the same Electrical supply. The system does have a return pipe. The larger capacity ensures you don't run lean (fuel starvation) on tuned cars as this can damage or destroy your motor, I think I'm Correct on this but welcome any corrections 👍🇬🇧
Old 02-18-2023 | 06:10 PM
  #110
Mr.Snail's Avatar
Mr.Snail
Update Winter 2023:
I am currently servicing the car over the winter here in NY and figured I would give everyone an update.
I have been enjoying the car thoroughly since my last post and have just been putting as many miles as I can on it.
Only updates of substance are adding APR R1 diverter valves and EVOMS F hose, in place of my Tial BOV set up. For sale btw.
& New set of Falken tires for the rear, fresh set of spark plugs with a coil pack harness plug replacement.
Here are some pictures from spring/summer/fall 2022, and now winter service.
The following 4 users liked this post by Mr.Snail:
Carlo_Carrera (02-18-2023), diverzeusy (02-18-2023), LinwoodM (02-18-2023), manimal (02-24-2023)
Old 02-18-2023 | 06:32 PM
  #111
LinwoodM's Avatar
LinwoodM
What made you swap out the Tial?
blockhed (02-18-2023)
Old 02-18-2023 | 06:46 PM
  #112
Mr.Snail's Avatar
Mr.Snail
For future ease of running the stock tune / maf to pass inspection. This way i dont have to swap it back and forth every year.
Old 02-21-2023 | 01:04 PM
  #113
royalflushness's Avatar
royalflushness
Love your car!. Do you have any detailed feedback on how the Falken tires perform on the street? Do they hook up in colder temps?
Old 02-24-2023 | 08:18 PM
  #114
Mr.Snail's Avatar
Mr.Snail
Thy have been a great summer tire, not recommended for sub 40 degrees. They easily hold my 450ish whp in warm weather.
Old 02-24-2023 | 08:23 PM
  #115
2fcknfst's Avatar
2fcknfst
They're pretty decent in the rain too.
