Clutch recipe with part numbers - did i get it right?
#31
it never slipped once. i only replaced it because my trans needed bearings. the rms r&r was *optional* lol. 40$ o-ring that it is.
#32
Just replaced my stock clutch on a 997TT also did the RMS that wasn't leaking.
BIG mistake! the new one leak! I didn't have the correct insertion tool.
Bought the factory tool replaced the rear main seal again that one also leaked
Then stopped after 500 miles WTF!
Both seals were from Porsche
#36
The wear on the outer edge of the disc and PP/FW is feature according to Sachs not a defect it will be normal after broken in.
This was in my video above when i went back in the replace the RMS.
#37
That is great news.
jayi836 (10-05-2020)
#39
i replaced my rms every and any chance i got. twice now. no issues and sure, no one wants a leaking seal. my conjecture is that any issues with replacing an o ring is the fault of the installation/installer. not the part itself.
heard good stuff about using the Luk parts. meaning oem equivalency.
#40
The flywheel has worked great so far but I only have 2000 mi on it. All the clutch parts have been great and I am very happy with its operation. If anyone was to drive it they would think the clutch was factory as the effort is just like factory. I do have some increased mechanical noise but that could be due to the window weld mod I did to the trans mount at the same time, either way it is not a big deal. Your welcome for the part list, I didn't see a complete one anywhere and I thought if it helped one other person it was worth the time to post it. I can't take all the credit because I got some recommendations and found some part numbers in other posts but I could not find the entire "recipe" in one place.
