how far up does your clutch "catch"?
my new turbo's clutch catches about 3/4 of the way up. my c4s catches about 1/3 of the way up.
does my turbo have a problem?
Too much power assist....too much travel.....those have been the 2 coments from day one........I'm not aware of any solution, there's probably nothing wrong w/your clutch.
As mentioned, you will get used to it, however........ if you're away from the Turbo for awhile, or go back-n-forth from others Pcars, it will take a few miles to re-adapt.
Too much power assist is right. The system is driven and assisted via the powersteering pump. It drives the clutch system as well and like the brakes will assist in pressure. They have done this since the 993TT. Not sure why when you consider the 3.6T can run the same clutch package without pedal issues.
I was also getting irritated that my motorcycle and my car were both so tiring to drive. The Ducati's clutch lever was brutal, I was going to change the slave cylinder to something more userfriendly on the bike and looked into the dual spring setup from the 3.6 Turbo to install on the C2 Turbo, but decided to buy the twin turbo instead.
So to all the wimps out there like me, to the assisted clutch and steering! :P
Originally posted by ignacio
fc
i must say that i also like the assisted clutch also.
fc
Hey, I love the car but even at that, when you're bouncing around a bit on the track...all that travel and hardly any feel isn't exactly an asset....just my opin.....we all have our own driving style I know.
I've relegated my 993 to some autocross & concours but drove that clutch alot in 6 yrs.....I'd take it, or the 986 clutch (or even the 996 clutch)....anyday to the Turbo clutch.
I'll admit I'm not very 'kind' to that part of the car (and as penance, changed over to the Sachs Motorsport Clutch).......just the same, the action on the 996turbo clutch has never made sence to me, whatever........but, at the end of the day, it's only a small part, of a great car .
gregg
the light clutch does help make the car a better daily driver. i disagree that it has no "feel". its just lighter and easier to use on a daily basis. to me that's what turbos are made for as opposed to gt3's and gt2's and probably most ferraris.
i do wish the catch point for the clutch was lower but i suspect in a month even that will be second nature. the turbo is just so capable and so easy to point and shoot. i don't mind it doesn't make me work too hard. i would never have a tiptronic, though. the turbo not a benz, thank god!
Still plays with cars.
Stephen,
I am curious about the difference between the TT clutch and the GT2. The latter is quite a bit heavier and has good "feel". I assume they are different. I wonder if TT guys could change a few bits and get the heavier but better feeling GT2 setup. FWIW the GT3 also has a high effort clutch compared to the regular cars. Like the GT2 the take up is very smooth and it is a pleasure to operate.
Regards,
Regards,
