A question of airbags...
I went up the valley today to see if I could help a buddy of mine that has a well optioned 2002. A little while ago, he tagged a parking abutment and ignited the drivers and passenger airbags, but not the side ones. They were replaced, but recently the airbag light came on. So I took my Durametric out and lo and behold, there was an airbag warning. I erased it, got a green check mark, let it run for a few minutes, turned it off, and when the ignition was cycled, the light came back on.
I suspect the part isn't correct. Are their model specific airbags over the 911 line?
Cheers,
Cheers,
And I, of course, was thinking it was simply the same issue I had when I canged my wheel, so I, of course, did not record the code.
Possible a connector is just not seated all of the way?
The impact wasn't great, rather a sudden stop.
The body shops I know have lifetime warranties on their work. Got to love it when a shop doesn't stand by their work, time to write a, um, "glowing" review.
Yes, it'd be nice....
We are starting to see more shops warranty for life, but it is in no way the norm north of the border.
Thank you I will pass this along.
Mine turns out eh airbag light and seat belt system light. These cars are notorious for the drivers seatbelt having a connection issue and it turns off the airbags. They wont want to go on if the seatbelt is not on. I have my cars 4th replacement seatbelt latch for the drivers side. Just need to put it in. So maybe check this? Just a thought.
Yes, I am thinking to go in first, and check all connections after the fix, and go from there.
Cheers,
Cheers,
