996 Turbo Forum 1999-2005
Any way to avoid mess draining oil tank?
Old 11-17-2019 | 12:45 AM
jayzbird's Avatar
jayzbird
Default Any way to avoid mess draining oil tank?
I completed my 10th oil change today, and each has ranged from a bit messy to an unmitigated disaster draining the oil tank. Today’s bright idea was trying to hold the plug in place to slow the flow. Fail: it was like a ceiling fire sprinkler—oil shot out sideways in all directions.
So my simple question: has anyone figured how to do this without oil splashing everywhere?
Old 11-17-2019 | 12:57 AM
boisenelson's Avatar
boisenelson
Just did an oil change myself this morning. I'm resigned to putting a big piece of cardboard under the car when I change the oil. Today my plan was to hold onto the drain plug and pull it away quickly when it reached that last thread and like always, it slipped out of my fingers and dropped into my oil catch causing the oil coming out to splash everywhere, including my clothes. I just plan on showering and doing a load of laundry after I change my oil
Old 11-17-2019 | 01:25 AM
TommyT's Avatar
TommyT
I use a Mityvac to suck most of the oil out from the top. Usually get about 6 qts. No mess when removing the drain plug.
Old 11-17-2019 | 01:37 AM
boisenelson
Just had an idea that I'm going to try on my next oil change. I order stuff all the time so I always have cardboard boxes hanging around....I'm going to try putting my oil catch inside of a cardboard box and I'm thinking that it should contain any splashes.
Old 11-17-2019 | 02:12 AM
jayzbird's Avatar
jayzbird
Wow, I never knew this was possible. I use it for my other German cars but not the Porsche. Does the tube just go down the filler hole?
Old 11-17-2019 | 04:19 AM
911mhawk's Avatar
911mhawk
Harbor freight packing blanket under bucket and fast hand with hot plug.
Or friends shop and make sure there's no Merc w/the window open nearby
TommyT (11-17-2019)
Old 11-17-2019 | 11:07 AM
pancing's Avatar
pancing
Looooool or your buddys face!
Old 11-17-2019 | 11:40 AM
Carlo_Carrera's Avatar
Carlo_Carrera
I too use the blanket and fast hands method.
Old 11-17-2019 | 12:06 PM
my04996tt's Avatar
my04996tt
I just let the plug drop into the bucket, then take it out after dumping oil into recycling container. No oily fingers or mess..
Old 11-17-2019 | 12:32 PM
T Kono's Avatar
T Kono
Not perfect, but works pretty well.....fold several layers of 1/2" mesh into your drain pan (in this case a buss tray from a restaurant supply store). Reduces the splatter considerably.
Old 11-17-2019 | 12:41 PM
pancing's Avatar
pancing
How are you guys getting splatter? I just position a pan to the left of the drain and it flows right in. Never had a splatter problem with the car on jackstands. I always change the oil of any car after letting it for an hour. Not a spot on the floor from my turbo.
Old 11-17-2019 | 01:19 PM
r6vr6's Avatar
r6vr6
I do cold oil changes and it comes out slower and I get more out. I put some thin pink board under the rear half of the car and position my oil catch container so the oil drains right into the hole in the depression in the oil catch basin. The car is jacked just enough that the catch container can fit underneath.
kmagnuss (11-17-2019)
Old 11-17-2019 | 02:18 PM
TommyT's Avatar
TommyT
yes. go easy feeding the tube in.
Old 11-17-2019 | 02:42 PM
kmagnuss's Avatar
kmagnuss
cold oil changes for the win. Plus it gets more old oil out of the engine.
Old 11-17-2019 | 03:09 PM
SOS's Avatar
SOS
I use a Mityvac to suck out most of the oil in the tank first, then pull the plug for the last little bit. I also learnt the hard way.
The Mityvac tank is measured, so I'll also suck the oil from the drain pan into the tank and I can measure exactly how much oil I've taken out. It makes it much easier to refill since we don't have dipsticks.
Quick Reply: Any way to avoid mess draining oil tank?
