Electromagnetic replacement for viscous diff
The difference in the rotation speeds of the front portion of the viscous coupling vs rear is a percentage value of the vehicle speed based on tire size (if you ignore any tire slippage,). So if the tire rotations created a 1% difference then at 100 rpm drive shaft speed, the differential rotation (difference between front and rear couplings on the viscous coupling) would be 1 rpm. At 1000 drove shaft speed the differential would be 10 rpm. So the torque transferred in straight line normal driving is directly related to vehicle speed. Now if to spin the rear wheels the rpm differential goes up dramatically. This is what people refer to when they feel the front pulling when the rear steps out.
This comment is not correct: the differential is mechanical so when there is a front/rear axle speed difference, the differential transfers more torque to the front axle. There is no variable of actual vehicle speed in the action of the differential, it's solely operating on a front to rear axle speed difference. So to obtain 40% torque transfer at 150mph would require significant rear axle slippage compared the front axle to reach the maximal viscosity of the differential and therefore maximal torque transfer conditions. Pretty unlikely to happen at 150mph unless things are really wrong!
I think you misunderstand how the viscous coupling works. It requires a speed differential between the front and rear wheels to work as intended (which is why the front tires on these cars are slightly taller in the front than in the rear, that was on purpose). As the speed of the car increases (and thus the axle speed differential), the amount of "slippage" in the coupling increases, raising the temperature of the fluid and increasing the amount of torque transfer, thus adding more "pull" to the front tires. The faster you go, the more torque there is transferred to the front wheels. Rear wheel slippage will also cause this to happen.
Seems to be an old wives tale of wanting taller front tires on this car. I've never, ever seen it written anywhere including factory books and would love to see it if I may be wrong. AWD cars should have front/rear tires matched as closely as possible. There's a slight variance allowed, hence the % of allowable difference, but always they should try and be matched.
Mechanical diffs are simple. I think the AWD system as simplistic as it is, works fine for it's purpose. Heating the fluid ( difference in speed between front/rear wheels) causes the discs to engage and activate the front wheels getting more power and thus grip.
Revs per mile is still slightly less on the rear. The sizing speaks more to what's available to match as close as possible than anything else.
The revs per mile are designed to be slightly higher on the rear so that there always a little torque to the fronts. If it is there are more revs per mile on the front than the rears, as the rear starts to slip there is a transition from slight drag on the fronts to applying torque to the fronts. I had a set of the Contisport DWS that had the stagger the wrong way (fronts smaller) but still within the 3%? recommendation. It had significantly more PSM interventions and had a squirreley feet at the limit as i transitioned in to the power. I put a stock size set of PS2s on and the car never felt better. i have since replaced only the PS2 rears and not the fronts and it is a little weird as i think the stagger is off.
on page 17:
OPTIMIZATION OF AWD PERFORMANCE USING VISCO-LOCK DEVICES
Visco-lock devices: The common feature of such devices is that the torque cannot be transmitted unless there is a speed difference between the input and output shafts. Therefore, these are termed speed sensitive devices. In other words, visco-lock devices act as a passive traction control system to regulate torque distribution between axles according to the speed difference (or slip) between them. If the speed difference (or slip) between axles increases, visco-lock devices bias (send) more torque to the side with a lower speed (front axle). The effect is, therefore, to deliberately introduce a ratio (smaller than unity) of the theoretical speed of the front wheel to that of the rear. This ratio can be tuned or optimised according to the viscous unit design parameters ... to meet the required characteristics.... The handling characteristics provided by visco-lock devices depend on the amount of transmitted torque. However, because there is no rigid connection between the axles (like viscous transmission) the tyres are still free to rotate with different velocities, so the problem of drive-train torsional wind-up is minimized.
...this represents the preferred option for applications in which the space is available and high torque is to be transmitted.
Front wheel speed to rear wheel speed less than 1:1 = front wheels rotate slower than rear, which means front wheels have larger circumference and diameter than rear.
And theoretically, if you had exactly matched circumference front and rear tires and no additional slippage from traction or turning, there would be zero torque transfer to the front.
If I'm interpreting this correctly, slightly taller rears would also cause the speed differential and create torque transfer to the front during straight line, full traction driving, but at small losses of rear traction (up to the percent that the rears are larger), it would actually reduce the torque transfer to the front instead of increasing it...
Didn't the 959 use computer-controlled clutches to continuously vary torque distribution? If so then the tire size difference doesn't seem to be a factor in its AWD system.
https://www.roadandtrack.com/car-cul...e-porsche-959/
This is along video but at about the 15:00 mark they talk about the AWD system and why the tires are sized as they are.
With larger rears the front diff is unloaded, getting no torque, so when the rears slip it takes a millisecond for the torque to surge to the front. With larger fronts the front diff is always torque loaded, ready to immediately react to the rear slipping.
And the PSM is the set up for larger diameters fronts too. I also have had PSM issue when just replacing the rears tires.
I wonder if anyone has more info about the different gear ratios on manuals vs. tiptronic S, as it is stated in the 996 bible. Is it true? What effects on 4wd was intended?
Btw I think the lockup on the 997tt front diff is PWM, so not going to work with just ramping the voltage. Someone did do some tests on controlling this some years ago, but I could not get any more answers in that post.
