996 Turbo Forum 1999-2005
315/30R18 Nitto NT01 on sale at Discount tire direct
Old 10-31-2019 | 01:35 AM
996TWINS's Avatar
996TWINS
Originally Posted by powdrhound
I found optimal grip and even tire wear at -3.5 front and -2.5 rear camber. For a milder set up for someone starting out, I would set the front between 2.5-3.0 and the rear at 2.0-2.3. If you are on stock suspension, I don't believe you will be able to achieve anywhere near what you need in the front. Basically get as much camber as you can in the front. Set rear toe at 15-17' per side, 30-34' total. Front toe at 2' per side, 4' total.
Does that work for both AWD and RWD?
Old 10-31-2019 | 02:32 AM
powdrhound's Avatar
powdrhound
Yes. I think Mtrbtvr6 is running those #s with success on his awd TT with NT01s. He’ll probably chime in.
Old 10-31-2019 | 05:05 PM
Mtrboatvr6's Avatar
Mtrboatvr6
Im running -3 degrees front, and -2.0 rear AWD and it works great! Im not on the NT01s yet but in the process of buying them in 245/315 flavor and will run them all next season with AWD. I havent heard of any issues with those sizes, but I track the car pretty frequently and will find out pretty quickly if they dont work. I am currently on 225/295 Yokohama AD052.
Old 10-31-2019 | 05:15 PM
911mhawk's Avatar
911mhawk
Ran this with PSS10s, Tarett camber plates, drop links and LCA's.
And with the JRZ's:
Going to more neg next alignment
Old 10-31-2019 | 05:23 PM
Mtrboatvr6's Avatar
Mtrboatvr6
And with the JRZ's:
Those are almost my exact numbers that im running. What spring rate? Im currently experimenting with 6 Comp 10 rebound front and 6 Comp 12 rebound rear. Helped with AutoX lower speed oversteer.
Old 11-01-2019 | 04:53 AM
911mhawk's Avatar
911mhawk
Running 700/800, will be going up this winter when I pull them for a rebuild & revalve.
Got 2.5 seasons before they started leaking.
I've been running them almost full stiff on the track this past year.
The track has been repaved, shocks are more used and I'm a little faster.
Here's another one to think about that I got from a friend:
File Type: pdf
Old 11-01-2019 | 05:33 AM
powdrhound's Avatar
powdrhound
Once you go to NT01s Ryan, you can increase neg camber another 0.25-0.5 degrees both front and rear.
Old 11-01-2019 | 09:16 AM
Mtrboatvr6's Avatar
Mtrboatvr6
Thanks John, planning on it for sure. I will have a second set of wheels this year so I can be more aggressive with the camber settings that the NT01s like. Oh and that rear rebound adjuster that froze, is still perfectly fine. Ive adjusted it a few times now with no issues. That was so strange!
Old 11-01-2019 | 10:19 AM
hybridporky's Avatar
hybridporky
These are honestly great tires for the price. But if you are looking for more versatile tires - but still track focused, go with the Yokohama A052s. They were on back order when i needed a replacement set, and decided to go with Nittos.
Street Use:
Rain: Honestly, scariest drive back from Lime Rock Park to Boston MA.
Dry: Decent, no drama
They are by far, the noisiest tire i have ever had. I have 245 fronts and 305 rears, and they literally create this booming-echoing noise even at 20-25mph.
Track:
If i were to do it all over again, i would get them heat cycled from Discount Tire Direct, they take awhile to "scrub in" (if that's the word), but once they do, traction is as good as the Yokohama A052.
I recommend the A052 overall because its PS4 quiet, and actually has above average traction in the rain. Hence a more versatile tire for those who dont trailer their car to the track, or wanna drive their cars as a weekend toy sometimes.
Old 11-01-2019 | 11:58 AM
Mbren1979's Avatar
Mbren1979
Any suggestions on hot tire pressure to start with on the 245 315 combo?
Old 11-01-2019 | 12:03 PM
Mtrboatvr6's Avatar
Mtrboatvr6
Street Use:
Track:
Ive run two full sets now of the Yokohama, and I completely agree. As a dual use tire its as good as ive found. Makes even less noise than the RE71R with similar grip level, but takes heat from a track better than the RE71R. They are staying on my stock wheels for AutoX/street duty. Nitto NT01 for track next year, im going to try them out. Just wish I would be able to run RWD and do the 305 like John suggested. All in due time.
Old 11-01-2019 | 12:29 PM
Mike Roblin's Avatar
Mike Roblin
32-33 HOT pressure. Make sure to check them mid session to get the most accurate reading. Or immediately after the end of your session pull over in the hot pits to take the temps. Don't wait until you get back to your pit area, they've cooled off quite a bit by that point.
Old 11-01-2019 | 01:13 PM
SOS's Avatar
SOS
Track:
How do your lap times compare with the NT01 vs A052? I'm a regular NT01 user but I'm open to new options.
Old 11-01-2019 | 03:11 PM
jayzbird's Avatar
jayzbird
It feels to me like the tires are rolling over at these temps, and they feel better in the high 30s. Anyone else experience that? My specs on 235/315:
Old 11-01-2019 | 07:54 PM
darr3239's Avatar
darr3239
What R888R failures? That's the first I've heard of that.
Quick Reply: 315/30R18 Nitto NT01 on sale at Discount tire direct
