996 Turbo Forum 1999-2005
Seatbelt
Old 10-07-2019 | 12:48 AM
blazen244's Avatar
blazen244
Default Seatbelt
Hate to be such a noob but there is a buckle under the passenger seat in my car and I'm curious to know what might it be used for? Any info guys
Old 10-07-2019 | 12:56 AM
Dock's Avatar
Dock
There's not one under any of my seats.
Old 10-07-2019 | 01:00 AM
blazen244's Avatar
blazen244
Its the wierdest thing it's attached to the bar underneath passenger front seat
Old 10-07-2019 | 01:05 AM
Dock's Avatar
Dock
Picture?
Old 10-07-2019 | 01:16 AM
blazen244's Avatar
blazen244
I'll add one tomorrow it's sitting on jack stands at a relatives house at the moment we're swapping the E brake cable
Old 10-07-2019 | 01:46 AM
T Kono's Avatar
T Kono
Child seat?
Old 10-07-2019 | 03:09 AM
garrett376's Avatar
garrett376
It's a child seat airbag deactivation switch. The Porsche child seat has a buckle that plugs into that, and when plugged in, the airbag is deactivated. Or, you can use any child seat and plug in a buckle that fits, to deactivate the airbag. If you remove it, you need to decode it from the Airbag module or you'll get an error.
Old 10-07-2019 | 11:19 AM
Mike Roblin's Avatar
Mike Roblin
Also, if you are interested in selling it I'd be interested.
Old 10-08-2019 | 09:32 AM
NoogaSparrow's Avatar
NoogaSparrow
Like said above...
https://www.suncoastparts.com/produc...BoCY0MQAvD_BwE
Old 10-08-2019 | 09:35 AM
NoogaSparrow
also if interested for a mere $380...
or for your toddler $840
Old 10-08-2019 | 09:37 AM
blazen244's Avatar
blazen244
Yes that's it ok thanks my kids are passed that age now I'll look into what's needed to decode it and maybe I will sell it
Old 10-08-2019 | 01:49 PM
Capt. Obvious's Avatar
Capt. Obvious
If I recall correctly it doesn't need to be decoded, you can just remove the bar and go about your life. You can test that theory by unplugging the plug on it and starting the car. If your ABS light doesn't flash or stay on you're good to go.
Old 10-08-2019 | 05:29 PM
garrett376's Avatar
garrett376
Like any part of the Airbag circuit, if you unplug it and turn on the ignition, you'll get an Airbag error which will not go away unless a tester removes it. And to code this bar out with a PIWIS, you need to have it plugged in first, then decode it, then unplug it. If you unplug it, sell it, then go to code it out later, you won't be able to without the bar plugged in. The programming process can be funny.
Old 10-09-2019 | 10:02 AM
NoogaSparrow
Hmm I thought it was like Capt. Obvious stated.. I had previously read the same, that you need to have it activated, but not deactivated.
Quick Reply: Seatbelt
