996 Turbo Forum 1999-2005
Lightweight Flywheel
Old 10-04-2019 | 11:15 AM
Carlo_Carrera's Avatar
Carlo_Carrera
Originally Posted by powdrhound
The GT3 crank has twice the oiling capacity of the TT crank. That is why I say the TT crank is inferior.
Why do think that is? Strength issue? The Turbo mechanicals produce too much torque for a GT3 crank to handle?
Old 10-04-2019 | 11:25 AM
powdrhound's Avatar
powdrhound
Originally Posted by Carlo_Carrera
Why do think that is? Strength issue? The Turbo mechanicals product too much torque for a GT3 crank to handle?
It’s not a strength issue in my opinion. I’ve been using a GT3 crank for 5 years . Most likely it was cheaper at the time to manufacture the TT crank in the larger numbers required for the TT production market. Porsche probably figured the TT crank was sufficient for the lower rpms seen by the turbo engine and they were not designing a crank for racing conditions which necessitated some design changes to the crank to improve oiling capacity. For vast majority of users and applications, the TT crank is more than sufficient.
Old 10-04-2019 | 02:27 PM
Carlo_Carrera
Are the Turbo crank and the GT3 crank the exact same spec except for the oil ports?
Old 10-04-2019 | 02:53 PM
powdrhound's Avatar
powdrhound
Both 76.4mm. The GT3 crank is a pound or two lighter if I recall. Can’t remember the exact number. I can weigh them when I get a chance as I have a TT, 7GT3, and the latest gen 991Cup crank at home.
Old 10-10-2019 | 10:19 AM
etchhead's Avatar
etchhead
I went with Sambo (ByDesign) suggestion: Clutch/LWFW GT3RS 4.0 and am a fan. As other say only get a bit of noise with AC in neutral. Push in clutch and goes away. It the rev is instantaneous- feels much quicker darting around.
Old 10-10-2019 | 03:31 PM
2fcknfst's Avatar
2fcknfst
I have Kevins GT3RS 4.0 version, a little chatter but I barely notice it.
In all my manual cars, and two diesel trucks, I have them.
Kevin's assessment with the 996tt is going with a lwfw would be akin to adding 30hp.
etchhead (10-11-2019)
Quick Reply: Lightweight Flywheel
