*996 & 997 Tiptronic - QUAIFE LSD Dev.- 30 Names Required
#151
As long as you have a plan to test and set it. I expect it will be like any other ring/pinion setup except the pinion depth cannot be adjusted.
#152
Backlash is very easy to check. I use something similar to this to set up gears on non-transaxles. Im pretty sure it will work for a porsche box. There r even cheaper mag base arms but it may be hard to find a good surface under the car.
#153
Hoping this project would be smooth sailing but it looks like I’ve run into an issue. After the recent conversations here t about mesh/ alignment and stuff, decided to take some measurements and found some issues. I’ll be calling Matt to see how I can proceed. I like to be positive and this is still progress and is hopefully getting us closer to a solution.
#154
That's unfortunate. What's wrong?
#156
There's probably enough meat on that flange to make it work; fingers crossed!
#161
Did the front LSD give you a noticeable improvement? On what exactly? Wondering because this could be an option as well for my tip
