Loose vacuum hose help
I’m in the middle of replacing my exhaust and when I took
Down the drivers side cat-I found this hose hanging. Any idea what it could be or where it goes? I’m thinking secondary air pump, my car throws the code every once in a while. Thank you!
coolant reservoir vent
Engine is nice and clean. Bravo on that.
Ive already replaced the n75-but I wouldn’t doubt it if was another vacuum leak; I still need to do a boost leak test...thanks for the tip!
Possible staining from the spoiler rams leaking?
Power steering pump leaks, blown spoiler rams, you name it! During my ownership I've replaced the power steering reservoir that dumped all over the place when it blew and the wing rams with eRams-now I'm just looking for a reason to do a GT2 clutch conversion to avoid even more pentosin in my garage.
Ugh, I hear ya! My rams just started leaking when I bought the car and I went to a static setup then GT2. Have all the GT2 slave parts sitting on the bench just waiting for some time to drop the motor and trans and tackle it. Pentosin makes a hell of a mess of the garage floor.
upgraded clutch
GT2 conversion
pinning coolant pipes
intake
intercoolers
hybrid turbos
injectors
throttle body
plenum
Basic Sponsor
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
