BBS E88 9/12" x 18"
BBS E88 9/12" x 18"
So I'm thinking I'll ditch these for something a little bigger, tires are MPSS 245/315 and are 50-60% rear, 70-80% front, 2 year old date code.
$5000+Shipping, they are perfect in every way.
Buy with confidence. Great seller!
And they are most sexy.
The gold goes well with the black.
Perfect rim for these cars. Well that’s my thought.
Good luck with sale. They should sell pretty quick.
Nice...
Hello, do think there would be any issues with fitment on an '01 Turbo with KW V3s at GT2 ride height? Thanks and love these wheels!
I am also running the GT2/3 uprights with -3 camber and -2.5 in the rear.
Here's a to plug sizes in and confirm they would fit fine:
https://www.1010tires.com/Tools/Whee...et-Calculator#
The front wheels actually protrude 4mm less than a stock GT2 wheel so you can run a 5mm spacer depending on camber.
The rears protrude 3mm more and fit fine but you can run a spacer there too depending on fender roll/camber.
Stock GT2 wheel offsets are:
18 x 8.5 Front ET40
18 x 12 Rear ET 45
Stock 996 GT3 offsets are:
18x8.5" ET 40
18x11 ET63
^ Thanks for the reply - I should point out that although I am at GT2 ride height, I have the stock turbo twist wheels which I believe are 8" x 50 and 11" x 45. Per the calculator, that would put the fronts at 13mm further out; and 16mm for the rear. I'll have to check how much more space I have but just want to make sure I can install these without any spacing, rubbing, or AWD issues. Thx
