997 gt3 brake master psm fix
Don't tell my fiance. She claims I've spoken more romantically about my 911 than I have about her.
Beautiful. So are you going to pull together a comprehensive kit? The MC, Jegs, and hard lines? When can we buy?
Does not affect the abs unit at all. Also it fits under the plastic in the master cylinder area. Cant.even see it if your plastic cover is on.
Yes it will have on a 996 either on stock brakes or on upgraded. The the master cylinders added flow and pressure that trips the psm failure, not the caliper or rotor upgrades. The added flow/pressure is just enough to trip the pressure switch in the psm pump to go into psm/abs failure mode.
Sorry guys. Been in the hospital with the gf here and havent got back to anyone. Few other guys have done the mod and working great. It's simple but works. You will need to add some.teflon tape to the NPT adapter fittings that come.with the valve because they seems to leak if you dont.
Looking forward to updates on the kit availability.
in for this as well...ready to order when you have the kits! hope you're well!
Before I post in the classifieds, wanted to throw it out to relevant peeps.
I put together the necessary components for this mod but haven't gotten around to install, and frankly, have been focusing on my new C2 more than the Turbo at the moment since the Turbo is about perfect in my eyes already.
- 997 GT3 MC
- Custom lines
- Jegs apportioning valve
PM me if you'd like this setup!
-Joe
- 997 GT3 MC
- Custom lines
-Joe
Good question : is this thread still active ?
Is anybody that have installed a JEGS pressure controler could chime back in and express comments on results ?
(I'm running a "GT2" master cylinder since some good time, and once on the while I got the error.)
THANKS A LOT
By the way, if reducing a little bit the pressure do solve the problem, then we should have more than one solution.
For example, I never heard about JEGS brake parts, ..but for sure, I have heard about Wilwood !
A Wilwood pressure controller do exist too !
See:
https://www.summitracing.com/parts/w...=true#overview
Hi gents, I performed this upgrade a few years ago on my RHD 2001 C4.
It was straightforward with no issues, and has eliminated all the warnings that I had previously when I fitted the GT3 master cylinder.
As I could not make up the new pipes myself (I do not have the tools or capability) I took the car with the JEGS valve to a hydraulic shop that specialises in manufacturing hydraulic hoses and brake pipes.
They actually custom make brake pipes for trailers, and were perfect for this (very simple) job.
Once they had made the 2 lines with the correct fittings I took the pipes and valve to my mechanic, he fitted them and bled the system as per the Porsche Service Manual.
Please see the photos, which are self explanatory
Newly made pipes
JEGS 63022 Valve
2 new pipes fitted to JEGS valve
Top pipe from Master Cylinder to JEGS Valve
Top pipe from Master Cylinder to Valve
Plastic cover cut to accommodate Valve
Plastic container painted and screwed over valve
Side view of home made cover
Newly made pipes
JEGS 63022 Valve
Newly made pipes
JEGS 63022 Valve
Newly made pipes
JEGS 63022 Valve
