What's difference between the GT2 engine and the Turbo X50 engine???
All that power to rear wheels.....and they let anyone buy it. Status is nice, but I think that a car like that should REQUIRE additional training at the buyers expense. If you don't know the limits in a controlled environment, your ego will find them in an uncontrolled environment. Just my 2 cents, and it is my humble opinion, no flames please.
the GT2 gear ratios are the same as on the regular 996, at least through 4th gear. i saw a car and driver where porsche rented the daytona track as a publicity event and they showed the inside of the car as the porsche factory driver took it around the track. he was driving it hard, taking it up to red line constantly, and the speedometer/tach showed that he was shifting at the exact same RPM/MPH ratio as i do in my 2001 C4. i can only say this through 4th gear because he never red lined it in 5th gear, and never even got into 6th.
It seems for curb weight(car with full tank of gas, no driver) in 2004
2004 996 GT2, 3175 lbs
2004 996 tt manual, 3505 lbs
2004 996 tt auto, 3594 lbs
2004 996 tt manual Cab, 3660 lbs
2004 996 tt auto Cab, 3748 lbs
Originally posted by cjv
"the GT2 gear ratios are the same as on the regular 996, at least through 4th gear."
teflon_jones,
I believe first gear ratio on the GT2 is 3.50:1. The turbo's first gear is 3.818:1.
teflon_jones,
Originally posted by teflon_jones
well, i don't think i saw the guy redline it in 1st gear since he was on a track, so that may be true. but he did redline it in 2nd, 3rd, and 4th, and the RPM/MPH ratios were the same as in my regular old 996.
