Temp Gauge fluctuation when HOT = + 5-10 Degreees
I run CSF rads, water wetter and new coolant/water pump/t-stat and sit right in the middle or just to the right on the gauge. Normal in 100 degree temps.
ok, so updated.
with AC ON this time..and after a spirited 1/4 tank run thru canyons & freeway w/ outside temps btw 85/95 degrees.. the coolant temp dash gauge while up steep grades and occasionally idling, never went above 185 and even then, only for short periods. immediately resting at a comfortable 180 back at sea level.
so, while i can hear/feel the DRIVERS side fan blowing profusely from the front at idle? the passenger side is far less noticeable, so i am still wondering if something is amiss. that said, given the consensus is this is all within "normal" range, i'll go find something else to obsess about unless this gets "worse" or the t-stat completely goes south. again, thanks for everyone's input.
Both fans should blow the same amount. Your passenger side fan may be on the way out.
Your fans should go into high speed at about 210 degrees or when you turn on the AC! If your fan is not in low speed on one side it could be the resister in the fan harness on that side. #4 in the pic below
http://www.autoatlanta.com/porsche-p...section=105-15
thanks carlo..both dont seem to be operating optimally. sometimes the pass side is blowing full bore.. but now its was only the drivers side blowing at full speed ( seemingly )
kevinmacd. thanks.. whats the best way to isolate if it is in fact a resistor possibly.., and not a failing fan on passenger side? is this a test with a durametric?
If you put your hand in front of the front tire in the wheel well where you see the vent in the fender liner you will be able to feel if there is air blowing versus trying to hear if the fan is working. When it's running with the AC on, it is easy to feel the air blowing when it's working.
yes, thanks.. I can obviously FEEL and HEAR when they are operating at FULL speed. but after this recent hard run, its was only the drivers side blowing on FULL> is everyone in agreement that BOTH should be blowing at FULL speed, and if the pass side is intermittent? that could be a resistor?
As these cars age, the brushes in the motors seem to get pulverized. My passenger side is awaiting its replacement to show up in the mail as I type... Too bad Pelican doesn't ship as fast as it used to in the past or I'd be assembling it back up today.
When the relay(s) under the dash fail the fan will run full speed all the time, weird. I found that both will NOT operate at the exact same time/speed. This was detailed somewhere I read a while back. Could I be mistaken, sure, but I'm very certain it went over the entire operation of the cooling fan systems/resistors and motors. But if the car isn't broke, and temps look fine, why are you looking for problems?
but NOW.. the only one that seems to blow at FULL SPEED is the drivers side. so..i am NOT "looking" for problems(?) per se. yet, this for me is *anomalous* behavior ( based upon my having owned two different 996 turbos over ten years ) in terms of the fluctuations and seeming increase in gauge temps when idling. i have NEVER once, in either car, seen the coolant temp gauge deviate btw 180 ( normal ) and 185 and even up to approx 190 in stop/go traffic or while idling HOT. perhaps you understand my concern? perhaps not. it's that i sense that a component of the coolant system is failing lol. i'm merely trying to isolate which if any. is all.
