PSS9 and Sway Bar Problems
Can anyone please comment about using adjustable sways and PSS9's. I understand that GT-3 sway bars require a curved drop link to work properly. There appears to be conflicting views as to weather H&R sways will work. Please comment about your set-up, if you had any problems, or if you cannot use your full adjustment range.
I have the H&R coil overs with the GT3 sways and TRG drop links, no probs. With the GT3 sways and the TRG drop links you will not be able to adjust all the way tight due to the drive shaft. But this is not really an issue due to the the understeer the turbo has. You will never want to run full tight.
![](http://gallery.rennlist.com/albums/Brakes-and-Suspension-Mods/TRG_DL_mounted.sized.jpg)
OAK, are your TRG drop links straight or curved? How much and form where? Do you have the new H&R sways that are quiet in the rear? Did H&R give free upgrades to those that had the earlier units that clanked in the rear?
I don't want to hijack the thread, but H&R will be offering free replacements for those with the early bars that rub.
I found out that there are differences with the cross members in the rear. That is why some cars rub and others don't.
Thanks Oak and Mike. My understanding is the H&R coilovers do not change the strut mount and they have no problem. The question is with the PSS9's and adjustable sways.
Mike was referring to H&R bars...
From experience, Mike is great. The day I got my H&R sways my tech called me and told me about the clearancve problem and we thought it was a defective bar. Mike overnighted me a brand new one and paid for the return of the other one. All this was before the issue was known (other members knew but no one told H&R or their reps). H&R was gonna design spacers but instead, they did it the proper way and went back to the drawing board. A new design is due out soon I hope.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
i installed quite a few of the pss9 with TechArt s/bar
and Eibach they work well(pss9 used shorter oem style drop link)
the adjustable drop link have tendency to come loose
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
the problem with PSS9s is that on my set the mount on the strut is much higher up than on yours oak... so they need to be longer. Also the angle is all messed up so when you turn the wheel it tends to try and bend drop links
Strange design on the PSS9 part...
hi oak... to be honest, I don't know.. I mean there are so many "different" versions. All I know is that if my design is a "correct" one then I would say it's a problem for other folks too...
I have the "early" H&R coilovers & the first H&R sway bars that were made. The rears bars really make a noise over normal uneven roads. I was going to change to another set up, but now it sounds like H&R is going to make good on the problem. The other problem I have is the front end is elevated about as high as it will go, but I still scrap consistently on driveways, etc. Any advice on what to do?
Code Red, drive slower over transitions. My lambo front end is 4" off the ground. I am used to it and you have to be careful.
I still don't have strong answers but I want to wait until some of the tuners get the new H&R sways on cars with PSS9s' and see if the problems are gone. It's way cool to see H&R fix the problem for you. Because of this, I will now give their products a shot.
TIm - waiting wont help as H&R is only coming out with a new/re-designed REAR bar...The front will be the same and since it seems here that the problem is with the fornt droplinks then more info is needed now. I personally need to check my DLs when I get back but I do not think there is a problem...
