creaking groaning sound in rear when backing out driveway
I have a groaning creaking noise when backing out of an uneven driveway or pulling in. it has been in the shop twice now and they still can't isolate the issue, the car has 86k miles on it, I just put all new ohlins coil overs and new lower control arms and way bars and swaybar end links and tie rods on the car , ( it was making the noise before this , and I was quite surprised that it still made the noise after all this, as I was quite certain it was something in the suspension, could it be subframe bushings? My car has been in the shop for two weeks now , and I really want this resolved, can anyone help me think about what is causing it, its just very irritating when driving around town in the car, it is only noticeable when dring slow over off caber/ uneven driveways t or pull ins either backing up or going forward, it only happens when the car essentially is twisting .
any help!!!! please.
they are trying to get a pair of chassis ears to listen while they drive it.
it was in for a week two weeks ago when they put the suspension on and they could not find it, , and now again for a week after and they still can't isolate the noise yet.
I had hoed the suspension replacement would eliminate the noise , but it did not.
my Mcgyver solution would be to either use a gopro or cell phone; mount [or tape] the camera to each corner under your car to find which is louder as you drive in/out of your driveway. Then, once you isolate the corner (or front / rear) narrow down even further by again mounting or taping camera to different places.
Since you're mentioning only low speeds, this should be very easy and able to do without a lift.
If it's not your suspension, that's all I can think of. It typically occurs at driveways, at slow speed, as the frame twists when the driveway meets the street.
Good luck. edit: here's one of the threads I recall. Actually the last paragraph of the post talks about a spray product for removing the creaks and squeaks. There are other threads on the subject if you want to do a search.
https://rennlist.com/forums/993-foru...ar-window.html
Check sway bar mounts and drop links to see if any are loose. Then lubricate sway bar bushings with a dry lube like graphite.
I had the same/similar issue in the past.
Installed a rear strut bar brace and the problem went away.
I did not want to remove and re-install the rear window and seal with lubricant as stated above and still have the noise come back.
