"clunking" noise in the front end when cornering hard side to side
Hi, wondering if anyone else has had this issue in there 996TT?
I sounds like something is loose in the front end, I just had all the suspension changed out and still the noise is there. it sounds like the jack is loose in the front and slamming to the left and right when jerking the steering wheel in hard cornering like on an autocross track,
We had it up on a lift for hours yesterday after the suspension was replaced and new swaybars with drop links and new LCA's the mechanic war worried the rack and pinion was loose not sure what to do about it.
hoping someone can direct me to the source of the problem if they have had a similar issue.
same noise still coming from front
and I also have a groaning creaking noise when backing out of an uneven driveway or pulling in. both really annoying and the front clunk is unnerving!
Update - it was my Battery!!!!!! it was not mounted correctly and was slamming back and forth!!!
Still trying to find out what the creaking noise is when I back out of an uneven driveway ..any help wit that would still be appreciated, it is coming from the rear.
Old post...but thank you!!
Just wanted to say thank you for sharing the outcome of your post. My car was making a banging noise on cornering so checking the battery saved me so much time. An Independent Porsche specialist here in Auckland (Aero) never secured the battery back in place after replacing it and lost the battery locking bracket so let it float around in the bay. They did the same with the fuel pump in the engine bay and that was clattering around too. You saved me a lot of diaggnostics :-) Much appreciated
