Spring Mod list completed
997 turbo 6 piston caliper (F), 997 turbo 4 piston calipers (R) with Pagid Yellow brake pads.
996 GT2 rear sub frame installed.
996 GT2 front inner tie rods installed.
Agency Power 3 inch intake Y-pipe installed.
Full all wheel drive differential service.
Full Tiptronic S trans. service.
I think I m done after 3 yrs of mods!?
Yes!!!!!! The pagid pads deliver huge bite!!!! Plus the calipers dont hurt either.
The Y-pipe is the only mod I have ever felt instantly while driving. The motor is completly transformed, ZERO lag now. It is coupled with EVOMS 3.5" interccolers so huge difference. The boost comes on faster than a light switch.
What wheels are those? They look great!
looks good. Are you tracking this car? Just curious because IMO stock brakes are fine for street. Be sure to clean brake dust off those wheels as the the pagid yellow will eat the paint. You probably also know the pads don't work great in cold until heated up. Those also look like ceramic disks, you forgot to mention this. Great work!
btw what does the GT2 subframe do for you?
Its just a lightweight aluminum part vs. the oem turbo heavy stamped steel part.
Looks ten times nicer.
Its the polished part in front of the GMG sway bar.
Looks great! What did you do with the rear wing, looks higher than stock?
Porsche Wing 12-way adjustable Mounts 996 Turbo
- Eliminates heavy hydraulic system, this system weights .9lb.
- Much less expensive then the OEM hydraulic system.
- Secure way of holding your wing at very high speeds.
- OEM look.
- Easy installation.
- 12 way adjustable to your liking.
- Extends up to 35mm higher then stock for adjustments needed at the track
- Instructions provided.
- Instructions provided to disable error for wing failure.
- Spanner wrench to remove oem hydraulics from wing, now included.
Anodize Clear Anodize $319.00 USD Black Anodize $339.00 USD Gunmetal Anodize $339.00 USD Custom Color $339.00 USD Polished Look $339.00 USD Brush Alum. Look $319.00 USD Your choosing color of anodize
^^ Thank you guys for the support in purchasing ebwerks products. If you have any questions please feel free to reach out to me directly.
p.s. OP - your car looks fantastic.
