996 TT SLAVE CYLINDER FAILURE?
NEW to Rennlist and Porsche ownership. My clutch pedal recently went STRAIGHT to the floor and did not reset. I can pull the clutch pedal back by hand but engine clutch inoperable. Slave cylinder failure? If so, does one always replace with the BBi Autosport Clutch Slave Cylinder Upgrade kit and how much does that cost? I could only find the part - not the cost. If being done by an independent Porsche-certified mechanic how many hours to install? Any other thoughts welcome.
Sean
2001 996 TT, 125,000 miles
Sean
Is there a puddle of pentosin under the car? If there is, check your clutch and power steering reservoirs. If they are good then there is a possibility that your clutch diaphragm spring has broken.
Slave cylinder?
https://www.ebay.com/i/263576835528?chn=ps&dispItem=1
https://www.partsgeek.com/gbproducts/SC/85-08019574.html?utm_content=SC&utm_term=2001-2005%2C+2007-2013+Porsche+911+Clutch+Slave+Cylinder+Genuine+996+116+237+52+01-05%2C+07-13+Porsche+Clutch+Slave+Cylinder+2012+2010&fp=pp&gbm=a&utm_source=google &utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=Cj0KCQjwnqzWBRC_ ARIsABSMVTMuQiP-hixNW7Bzr6Ry1GrNs-MONQZXZQjUm-OzHAaUGWS7tAR-o8kaAiz4EALw_wcB&ad=47433965052
DIY Replacement
http://www.rmeuropean.com/porsche-99...placement.aspx
You can sometimes use a strap wrench like this on the accumulator.
https://www.motosport.com/product/?a...=badger-street
DIY Replacement
Slave cylinder?
DIY Replacement
DIY Replacement
Slave cylinder?
DIY Replacement
DIY Replacement
I replaced mine not too long ago and all in all it took 4-6 hours to do the slave cylinder and the accumulator. Parts were around 500 bones.
380 for the slave.
https://www.sonnenporscheoemparts.co...er-99611623752
127 for the accumulator
https://www.sonnenporscheoemparts.co...c=YT1wb3JzY2hl
380 for the slave.
"Our kit is our very own proprietary design and does not plug the power steering pump because the plugs can fail. Instead, the power steering fluid is routed through the unit to simulate the factory system...."
Factory GT2 is larger job with more labor. Do the Google
Former Vendor
We also have the slave cylinder in stock, enter RENNLIST at checkout to get 10% off the price.
https://www.warehouse33auto.com/GENU...996-116-237-52
-Jason
-Jason
