LED Fog and High Beam Bulbs
This was addressing the concern of putting an LED bulb into a halogen housing (high or low). Ie, if you have a projector lens LED will possibly work ok, if you have a reflector housing it will likely never work.
Just saw this thread. Recently I upgraded the H11 hi beams to this version of LED. 16W draw and about 2x the output of a halogen. The difference is amazing on back roads
https://www.headlightrevolution.com/...1_2?quantity=1
I've done the foglight upgrade but haven't done the HID looking to make that change when the HIDs die but it shouldn't throw a code
That's good to know, that there is no code.
Think I'll do the fogs, just replaced the hids a little while ago.
