996 Turbo Forum 1999-2005
what wheel widths for 996 TT/C4S?? tia
Old 12-26-2003 | 12:33 AM
e46 M3 owner...for now's Avatar
Default what wheel widths for 996 TT/C4S?? tia
Just wondering what the wheel widths are for 996 TT and C4S.
Additionally, what are the most narrow and widest that work well
with these wheels?
Just wondering for...
Winter tire size...I presume 265/35 r and 225/40 f
for track or summer tire, could you go 235 or even 245 front?
On rear, is 275 through 305/315 ok?
Thanks in advance.
Old 12-26-2003 | 12:35 AM
Viken's Avatar
Viken
Keeper of the Truth
Standard wheels:
8" x 18" - ET50 - 225/40-18
11" x 18" - ET45 - 295/30-18
No point in changing widths unless you apply more downforce to compensate for lost pounds per square inch.
Winter wheels:
10" x 18" - ET47 - 265/35-18
Old 12-26-2003 | 12:39 AM
thank you.
with your statement in mind about adding downforce, I take it that most people opt for the Mich. PSCs since the stock sizes are readily available...?
I noticed hoosiers max at 275 and also wondered if some like to go 285 rear/235 front to dial out understeer a bit...
Old 12-26-2003 | 12:45 AM
Viken's Avatar
Viken
Keeper of the Truth
Like I said, there is no point in adding more rubber if you do not compensate for the pounds per square inch. The larger footprint of a 235 will do nothing more if you have the same force pushing it down against the pavement.
Old 12-26-2003 | 01:52 AM
sharkster's Avatar
sharkster
what if u have a gt2 body kit
Old 12-27-2003 | 03:56 AM
ebaker's Avatar
ebaker
235/40-18 (25.2 OD) and 315/30-18 (25.4 OD) should work OK on stock Turbo rims.
Quick Reply: what wheel widths for 996 TT/C4S?? tia
